Froneck
Titanium
- Dec 4, 2010
- McClure, PA 17059
I hope I used the correct word Geometry. I simply want to know the dimensions of a drill. I have a Darex Drill Grinder M5. Purchased new with all the drill chucks including the one needed to grind drills over 3/4" (up to 1-1/4" I think). Managed to get 2 more from HGR quite cheap but in surprisingly great shape. One had the stand missing but I was able to find it on ebay, a guy was parting one out. It also has the top of the right side holder missing (lower part is complete) that's used for split pointing and other point modifications. I didn't care since I want to make one to do point modification on drills larger than 3/4", it's not possible with what is supplied for grinding the large drills. The other is complete.
Also missing was the drill chucks for both grinders. I really don't need them having all those available except the left hand drill type. Seen them on ebay but the price was ridiculous.
However I want to make a few chucks and thinking about using 2 small ER Type or similar collets. I'm hoping to find a type that has a smaller OD than the ER-25 for a 5/8" drill. I have a customer that I grind a few drills for so I want very accurate holder for only a few sizes. I have ground 0° rake on drills above 3/4" using my surface grinder using a 5C 7/8" collet however I've found the 5C collets don't hold drills on the flute side well. To get the drill to align properly I made a bushing that was screwed into the collet stop threads. Worked enough to grind the rake.
I know the diameter is tapered, large side nearest the point. Where does the taper end so that the shank is straight?
