Froneck
Titanium
- Dec 4, 2010
- McClure, PA 17059
My question is a bit off topic here but I have found that the skill of those in this topic far exceeds the others!!!
I have a Darex M5 drill grinder, actually 3 of them. Currently I'm using 2 of them to do 3 operations on the drill. Point angle, Split point and Negative rake grind. The M5 will do 2 different grinds so I do a third in another grinder so I don't have to re-chuck the drill.
I'm currently grinding new 1/4" Michigan taper length drills with 118° point angle into 135° Split Point with negative rake to drill acrylic. I test the drills to insure they drill onsize by drilling acrylic with WD-40 lubricant (as being used by my customer).
If I grind the 135° and split point I get .250 hole size but if I add Neg. rake hole size opens to .255 to .260. I tried the grind on a new jobber length Precision Twist Drill and complete grind produced .250 hole. I had a few packages of 12 drills, one package produced .250 to .252 holes and within my limit.However other packages do not test within limits of +.003
Any suggestions? Any thought as to why? I also did some 118° by simply split pointing existing 118° drill with same results .250 hole diameter but when adding the neg rake hole size increased. The 135° + SP grind was done on same grinder, I reversed the operation and did 135° and Neg. rake on the same grinder Slit the point on the other with same results.
