Hey thanks for the info Larry. I believe the original motor is inside.I was given the original parts for the entire machine,accept the manual as he could not find it.But is calling if he does. I will probably leave the machine as is and just enjoy using it daily. I have several tapmatics and many machines so my tapping needs are pretty well covered.
I do use a ton of small drills between #55 up to a #19. Everyday. I make custom knives by hand with all of my old machines.I think this little drill will be excellent for running the small drills.
I also picked up a linley jig borer That is basically brand new. It indicates at zero.the dial didn't budge on a 6" circle plate. I have not indicated the drill yet but I was told it is the same, I'll need to make a 1/4" Holder for my indicator to have a look. I'll share photos of the linley if anyone cares to see?
Sent from my Pixel 3 using Tapatalk
