Early Cincinati Milling Machine tool and cutter grinder
maynah
Stainless
Mar 24, 2005
Maine
Early Cincinnati Milling Machine tool and cutter grinder
At least I think it's a T & C grinder, and it's early to me. A scrapper knows I'm a sucker for this stuff and trolled it past me. When they come right to your door yard it's hard to turn it down.
It's probably missing a lot of accessories, but is it useful for anything as is? The spindle has no noticeable play moving it by hand. It's hard to read with the lettering filled with paint, but I think the patent date is 1890.
I tried to edit title to find the missing "n", but it only changed the title in the first post, not the main page title. Is there a way I can do this? Thanks
Maynah,
You're kidding, right? I mean, buying that is such a blatant no-brainer for anyone suffering from Old 'Arn Disease that I'm surprised that your wallet didn't burst into flames from the friction as you yanked it out of your pocket at light speed !
What is this "useful" thing of which you speak? You'll find a way to use it, believe me. You have a grinding spindle with a way to apply it to a workpiece in a controlled fashion. You can use it as a small-scale surface grinder. Fixtures for grinding just about anything can be made.
John Ruth
adh and John, you're too fast for me.
The dial, lock knob, and pointer are all early elegant. It had a lever with it that looks like a small horizontal mill hand lever, with gear sector, but there is no mating rack gear on the table. The last picture shows a spot where some missing piece went on the rear of the table screw. Any ideas what it was?
Quite Similar From 1903 Catalog
For your enjoyment. :)
Additional closer-up scan added
Intended work description added
Looks like it's intended for grinding "bevels", ... as found on all straight "knives", ... like for wood Planers, Joiners, Moulders, or "Guillotine" type Paper Cutters.
With the addition of a set of "centers", you could grind cylindrical shapes, ... like the "bearing" shoulders on shafts, or any sort of ground bar stock, ... like "Thompson" Rods.
Doesn't take up much floor space, either.
Thanks to John Oder's post, (thanks for the extra scans), and moving things around a little bit, I do see where the table lever goes.
Everything is neatly tucked inside the column, and the rack gear is hiding under the table.
Here are some set ups from a flyer that seems about the same vintage as the 1903 catalog
Note the 12" inserted tooth face mill - those blades would have been carbon tool steel in 1903
Have you gotten any further along with your grinder? I just picked up a very similar one. Looking for any information, parts manual, operation manual etc. Preferably as pdf's.
I will post photos later, its a bit of a jumble at present as we disassembled it to get into the basement shop.
(Partly answering my own post: Cincinnati Milling Machine Co. - Publication Reprints - Universal Cutter and Tool Grinder | VintageMachinery.org has a good document for the Universal of 1901
Gerrit
Welcome to PM Gerrit. Mine is pretty far down the list for me to do anything with. It's just resting comfortably in my barn waiting it's turn. Thanks for the link
I have a similar grinder as well. I'll try to get some better pictures for ya.
Well, I am a happy 'victim'. While I initially will use mine for final grinding of lathe tools and d bits, I can envisage some surface grinding and also shopmade counter bores. It will certainly outlive me given how solidly this is built.
We broke the machine down to major assemblies before loading onto a small trailer (along with a small horizontal mill). Then into the basement via outside stairs and a 2 wheel cart.
Given its age things are in great condition. The paint is banged up and a few things have 'critical adjustment' hammer marks but the ways etc. show no wear. Below a series of photos showing various components.
There was an equivalent type of machine at the large shop where I served my apprenticeship. It had a six inch wheel with diamond around the circumference, 3/16" and radiused. Shear lips as they were called were ground on the top surface parallel to one edge of carbide triangular inserts. Great for reuse of old carbide inserts and they performed very well for finishing cuts O.D. or I.D.
John
Here's a few more pictures of the grinder I have.
You've got a boatload of accessories there. In the other tread I linked to, I think there's a link to the manual for this thing, where it lays out all you can do with it. Quite the toy!
And like the flyer says, "Any boy can run it."
Chip
I have just acquired a similar machine, which came with no tools, but I picked up for a 100 notes.
I can’t use it yet as I have a spur gear missing that drives the table, also there are supple differences between mine and the ones in the photos.
I have adapted Clarkson centres to fit it along with their t & c head. As a former T & C grinder who has worked on Elliott, Cincinnati and J & Shipman T& Cs I rate this above the ‘orrible Clarkson T& C machines. As tool grinding comes easy to me as I have served a 5 year apprenticeship in my youth, I will have no problem grinding end mills, slot mills and other milling & lathe cutters.
Re; “My biggest holdup in testing that statement is the need to manufacture a wheel guard or two”
All you need is a large enough tube , even a soil pipe cut it down the middle, braze or drill & tap a split collar on top to take a 3/8 inch rod and mount it to a clamp on wheel head. a bit like the J&S wheel guards- I am in the process of making one myself when I have time. H.T.H.
