Old Reed&Prentice
Ultradog MN
Cast Iron
Jun 14, 2020
00X0X_aPnLXfPA6BWz_0t20CI_1200x900.jpg 00x0x_diLyHVgt2uaz_0t20CI_600x450.jpg
I might look at this lathe but am wondering what info I can gather here before I go.
Can anyone tell me what the top rpms of this machine would be,
Also any idea of the size? Seller doesn't know.
He says it's a flat belt drive which I'd guess predates the chain drive RPs.
I don't need a real modern machine but I do want one that will turn 1000 rpms or so.
Thanks for any info.
View attachment 314563 View attachment 314564
Take better fotos. Frame them. Hang 'em on the wall. You and Reed-Prentice have done yer duty.
Now go find a newer lathe you can set on the floor and make chips with.
That simple.
I'm fairly certain that is a chain drive model. Also known as a "silent drive"
Mine is a little newer but has the same layout. That long end cover has the chain drive behind it.
Hodge
I have a friend who has a Reed Prentice, the ways by the chuck are very badly worn, I would check the ways before anything else.
Keep us posted if you decide to follow the machine home! I am parting out a similar machine and may be able to help with some missing parts or damaged gears
I have the same machine in the 14 x 30 size and i love it. Mine has very little wear and works great. Headstock has spur gears so it's quite loud but it is a very stout and accurate machine.
