Indtools&mach
- Nov 13, 2013
- Millstadt, IL
We currently have a Early Reed Prentice 14" Heavy in the shop RPM range 18-432. Serial number is 5286. This model does not have the range selector to the left on the change gear lever. The end/banjo gears get changed to switch between compound and direct for more feed speeds. It is currently set up for compound feed: from feed reverse gears they drive a 28T gear which drives a 40t attached to a 20t that drives a 50t attached to a 25t which drives a 60t attached to the quick change gearbox shaft. Does anyone have a picture or arrangement of the gears for direct feeds.
