Silverfox1947
- Sep 7, 2017
Who buys an old lathe in boxes then goes home to find out what he bought, I did, yes, I am an idiot.
The lathe turns out to be a IXL Leader circa 1936 no: 30221 ver 2. (Thanks to Tony Lathes for his help with the identification)
I was told it worked before being stripped down and boxed as you will see that was unlikely.
I will list my mistakes: Do not start the rebuild before checking everything, hence I am now stuck. Buying an obscure lathe which needs everything made for it as you cannot get parts off the shelf is also questionable. After using grinding paste on the carriage ways to smooth out years of wear and putting the lathe back together again. It jammed point to point under power with the hand wheel pinion jammed against the rack. What had I missed? Nothing, I had noticed the carriage wheel falling under it's own weight at one point in the rack and my way leveling had lowered the pinion to rack distance just enough to allow that play in the rack and pinion to jam. On removing the rack it was worn. Hence I'm now trying to locate a rack or get one made. If anyone knows where I can get a rack, I also need an original left hand head stock gear cover which was missing.
I have fitted new chucks and back plates (5" Pratt and ER40 collect) had new back gears and the damaged or missing change gears replaced.
Yes, this project is being done in my living room, for that you also need a very understanding partner.
Project so far: I located a pair of old cast iron legs probably from a treadle lathe.
First tip get them ground square top and bottom (I didn't). I started by making a wooden platform and steel drip tray for the lathe to sit on (mistake). Mod two was to replace the wood with a full length 12mm steel plate (which doesn't move and holds both legs together and aids leveling. Once the lathe was bolted down I decided to make leaver system that is operated by foot pressure. That downward pressure slackens the belts and disengages the drive. I used the treadle bar, a gate lock to lock it down if required and an adjustable lifting bar to allow adjustment of the belts in working position. The motor was replaced with a reversible Jap motor which pivots from the 12mm steel plate and is not attached to the lathe itself. The poly-carbonate flywheel and change gear covers were originally designed to watch the parts working during the initial stages of the project. Some have asked is it an "art instillation" or a lathe, I have decided I like them and their staying.
Have a look at the pictures and if any one can help me save this almost but far from finished very expensive project that I probably should never had started please contact me.
Roger (In Bristol UK)
