jljim
Cast Iron
- Jul 24, 2004
- Northwest Ohio
14x36 Rockford Economy Lathe. Flat belt driven with a Drive All 4 speed conversion. 3 jaw chuck, missing the jaws, grease zerks where the oil cups should be. Spindle bearings seem tight, ways are pretty good, cross slide screw backlash isn't too bad. Has a steady rest and faceplate, lantern style tool post. The only thing I know that's bad is the back gear needs some dental work, a couple broken teeth. Heavy layer of oily grime covers the whole machine, I've had it stored for nearly 10 years. It had a twin brother with a little more swing over the ways, cut into pieces before I got there...250.00 loaded on your trailor ?
