Froneck
Titanium
- Dec 4, 2010
- McClure, PA 17059
I purchased quite a few Grobet Swiss Pattern Files 8" tang not included.(not needle files) Expensive but work great! I make a small item (less than 1" long) One side has lathe cut radius of .900" in the center and .25 radius on each end. .25 radius is small on each end. I did use a corner rounding mill but still have to blend the two, material removal so little in most cases I file it. Material is bronze. Question is can I make an outline needed and harden the steel to use it as a template attached to my part to get consistent radius part to part. But not damage the file. File to slide over the surface with no attempt to remove any of the hard metal since the purpose of using hardened steel is to not have it altered by the file yet I don't want my expensive files damaged by the hard steel.
