Jeffrey Caldwell
- May 20, 2019
So my semi regular trip to the scrap yard today may have cost me more than any trip to date. In the back corner, amid a few old and not so functional machines, I spot this glorious piece of American history. Problem is, I don't know anything about metal working tools. After some googling, some reading, some reading and some googling, I've finally found a reason to register on this forum (which is my go to search string anytime I embark in a project, building a cnc router table (practical machinist), should I mill with a drill press(practical machinist), is this drill mill worth a d**,ect).
That being said what we have (if I can get pictures to load), in my novice opinion, is a brown and Sharpe #1 horizontal mill, with a Tree 2UV mounted to it. The spindle felt tight (didn't take my dial indicator because I didn't know I would be looking at machinery), all the slides work smooth as butter given how much crud is built up on them, spindle turns, ect.
Problems here:
1, This thing slid off a roll back when it was dropped off, (although the only noticeable damage so far was it shifted the belt housing causing the pulleys not to mesh correctly until I reseated it and a bent handle on the y crossfeed) .
2. It has absolutely no tooling included.
3. All my research says this thing is going to weight around 3k pounds. I would be paying 25 cents a pound for it (although more on this later, I think I am only in if I can get this sup 500$.
4. The Tree head uses z collects which are available but from what I'm gathering, non standard.
5. The Tree head uses a pancake motor which apparently is about 1.3 million dollars to replace, and harder to find than than a numbers matching shelby. This one is full of dirt, either from the landing coming off the flat bed, or years of wasps using it as a penthouse suite.
6. I've read on here somewhere regarding a similar machine I believe they call radial drill mills that the head rotating on a simple shaft such as this one leads to a less than stellar overall accuracy.
7. MY WIFE IS GONNA KILL ME IF I GET THIS. (Sorry for the caps lock)
8. *edit* also the power feed for what it's worth on the brown knee may or may not be operational, hand turning the belt, watch the gears spin inside mil, but can't get any combination (from what I can tell, no stamped on user manual here) to drive any part of the table.
So I've gotten in touch with zpsusa who claim to still stock all the parts to rebuild the head, and I'm getting the tools together to go back and give her a real once over, but I'm really looking for some guidance here. I've got a soft spot for things older than most people walking the earth, things that helped win ww2, sent men to the moon, things from a time when the country bonded together for a greater good, ect.
Am I lost here? Is this a terrible machine to dive into machinist land with? Is even 500$ too much? Alright, I'm sorry for the rambling, let's see if I can figure out images.
Looks like it may be uploading sideways? Chances of an admin being able to fix? I see no option at least from the phone here.
Thanks for reading, and I look forward to being an active part of this forum.
V/r
Jeff Caldwell
Problems here:
V/r
Jeff Caldwell
