Flather Lathe - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
Thread: Flather Lathe
  1. #41
    Aug 2004
    ventura,ca.usa
    369
    62
    Hi Dave,I went to school in Florida with Robert is why I asked,like you say, not a common last name. (I was in the bee's myself,1973-77 MCB5, a CE ) Merry Christmas. Jim
  2. #42
    Nov 2017
    Massachusetts
    23
    Quote Originally Posted by jmm03 View Post
    Nmcb4 for me. My uncle Jim has lived in Florida since late 70's. Sorry no James. You have a nice holiday as well.
  3. #43
    Nov 2017
    Massachusetts
    23
    Quote Originally Posted by Dave Rynearson View Post
    I meant "sorry no Robert"
  4. #44
    Nov 2017
    Massachusetts
    23
    Still trying to sell this lathe. I could really use the space.
    The machine is located on CT/MA border 1.5 miles off I-84. Have a crane an able to load.
    Thanks. Dave
  5. #45
    Feb 2017
    Ohio
    97
    8
    What size swing is it and how big is the through hole?
  6. #46
    Jul 2007
    Stratham, Cow Hampshire
    4,203
    404
    1578
    As my No. 715 was the same lathe apparently the same size I'll hazard an answer and say:
    Through hole is a little larger than 1 inch - I passed a 1" drive shaft for a Model A Ford through the hole to work on the pinion retaining threads.
    Swing about 7-1/2 over the bed (15 swing), a bit less over the cross slide/compound.
    Will hold 36 inches between points on centers.
    My lathe with motor and Drive-all weighed about 1750lbs total. Best would be to remove everything above the ways and the legs below for transport. If you remove also the quick change gearbox (4 square headed 1/2" bolts approached from between the ways.) you can put the bed on pipe-rollers and roll it across a concrete floor - or planks on a lawn.
    Dave can update the dimensions as its been 25 years since I owned No. 715.
    Joe in NH
  7. #47
    Jul 2009
    Munster, In. USA
    2,342
    478
    721
    Loaded my Flather 16" (17") by blocking up the headstock end. Removed the headstock legs and backed the truck under the bed. Added some pipe and lowered the bed onto pipes in the bed. Rolled it in and took the rear legs off.
    John
  8. Likes Paolo_MD liked this post
  9. #48
    Nov 2017
    Massachusetts
    23
    Quote Originally Posted by Brodytonelotti View Post
    All Joe's information is correct
  10. #49
    Nov 2017
    Massachusetts
    23
    First $400 takes it. Have a 4 post truck lift to put in and really trying not to put lathe outside but it is majorly in the way.
  11. #50
    Nov 2017
    Massachusetts
    23
    Trying to avoid craigslist as the legs will get taken off and the rest will be scrap. Nice piece of history to get melted down.
