marka12161
Stainless
- Dec 23, 2016
- Oswego, NY USA
I bought this a couple years ago with the intent of restoring it. It does have a few issues which could be resolved with a bit of work. However since buying it, other projects have pushed it farther down the priority list so i'm looking to pass it on. Issues are:
* The linear bearing on the bow has some wear and needs to be built up. The bearing surfaces themselves are brass (or bronze) strips. Build up could be done with epoxy or braze.
* The bull gear has been repaired. It is fully functional but looks a bit wonky.
* The guard for the bull gear is missing. I have a replacement that needs to be attached.
* The motor mount is also a bad retrofit.
This is free to whoever is willing to come get it in Oswego NY. If you want to make a token donation to the shop in return (couple of end mills, dial indicator etc.) it would be great.
If on one claims it by Nov 1, i'll take the vice off of it and call a scrapper. I can load.
Send me a PM if interested.
Mark
Mark
