Froneck
Titanium
- Dec 4, 2010
- McClure, PA 17059
I'm making a gauge to measure length of a slot. Have 1/4" stick X .900 stainless steel bar. (SS because I just happen to have a piece 1/4" X 1 X 6")
Purchased spherical point set screws 8-32 (only thread pitch available in #8) Drilled and tapped 8-32 X .8 deep and .096" thru for hex wrench.
Screw moves easy, I would like to stiffen the movement. Thought of hitting the side of the bar over the tapped hole with a punch. Maybe use an end mill and put a hole thru the side enough to remove threads on one side of tapped hole. Re-tap to remove burrs then press in a piece of Nylon or some other plastic.
Any better ideas??
Any better ideas??
