Dave Vincent
Cast Iron
- Nov 4, 2006
- Rochester, New York
FS 1920s vintage G&E 16 inch Shaper (Photos)
I have a 16 inch G&E Shaper that I would like to sell. The last patent date on it is May 21 1918. This machine has the factory electric motor drive on it. The motor is a 1200 rpm 3 hp 3 phase. This machine has manual oiling on it, there is no oil pump. It has a stand table. It has a vice and handle, crank handle, tool holder, front support , poke tooling for internal key ways, a gallon of oil and a G&E parts book . It comes with every shown in the pictures if they come up. The shaper runs good the only reason I am selling it is that a couple of years ago, I got a Hendey 12 shaper and it is much handier to use than the G&E (auto lube) so it just sits there and I need the space. The machine is under power so you can try it.
The shaper is located in Rochester, NY. I am guessing it weights between 3500 to 4000 lbs I hauled it home on a 5x10 landscape trailer that had a 3500 lb axle in it, but I only had to go 15 miles. I can load this on a low trailer providing it fits trough my garage door. I know the tandem axle Uhauls will. I know you could haul it on Uhauls tandem axle trailers with no problem. Another member hauled home a newer 16 inch G&E Shaper that weighted 4500 lbs with no problems.
Price $500
If for some reason the pictures don't come up email me at [email protected] you can email me with questions or comments or here on the PM.
Thanks for looking Dave.
Price $500
