Maltesehunter
Cast Iron
- Apr 25, 2008
- Elk Grove, CA
I would like to find a new home for this lathe. This one was saved (from Sonoma County) with the intentions of passing it on to someone else. Most likely it is 1840s or 1850s vintage. I have not found a maker's mark anywhere, but it closely resembles the Woodburn & Light lathe at Kinzers, which is dated 1848. It is not a huge project, but will need some work to get it in good, running order. Asking $650. Located in Wilton, CA.
Thank you, Jake
Thank you, Jake
