Granite State Mill Jig Borer
Likes Likes:  0
Results 1 to 7 of 7
    Mar 2005
    Maine
    1,348
    9
    568
    Default Granite State Mill Jig Borer
    This is on Maine CL. It must be scarce if Milacron had never seen one.
    Milling machine
    Milacron's post from 2007
    http://www.practicalmachinist.com/vb...1942-a-114083/
    Attached Thumbnails Attached Thumbnails granite-state-mill-1-cl-500.jpg   granite-state-mill-2.jpg   granite-state-mill-5.jpg   granite-state-mill-3.jpg   granite-state-mill-4.jpg
    Mar 2005
    Maine
    1,348
    9
    568
    I just noticed the image of the brochure in the ad is the same as Milacron's post. Same handwriting on the top.
    Sep 2018
    Rhode Island
    I've got the same machine. It's not in as good condition as yours is. I'm in the process of restoring it.
    How do you take the top pulley off? I've got head of but I can see no way to remove the top pulley without damaging something.
    Mike
    Mar 2005
    Maine
    1,348
    9
    568
    That's not my machine, I was posting because it was scarce.
    Post a picture of the pulley and I bet someone here can help.
    Are there set screws in the middle of a Vee groove?
    If you take one out check for a second under it.
    Sep 2018
    Rhode Island
    There are no set screws in the middle of the Vee groove. I was able to remove 3 screws from the underside of the pulley that holds on a brass ring. However, even after removing these the pulley wouldn't come off.
    Mar 2007
    L'Orignal, Ontario Canada
    2,135
    1830
    867
    I’m not sure about this machine but on some drill presses and other small mills I have seen the front cone pulley fits on a short hollow tapered spindle that runs in a pair of ball bearings that are in a housing attached to the top of the machine .
    The bore of the spindle has internal splines of carries one or more keys .
    The splines or keyways of the main quill spindle slides up and down through and is driven the top spindle .
    The pulley has a tapered bore to fit the upper spindle and is some times held in place by a special nut in a counter bore on top of the spindle that may need a special pin wrench or spanner to remove it .
    It may be a bit tricky to pull the pulley from the taper if it has been on for a long time.
    I would suggest NOT using conventional 2 or 3 legged puller with much force over the outside of the grooves pulley to remove the pulley from the taper since you can damage the pulley very easily but rather something that threads in place in the bore of the retaining nut if there is one .
    You may have to make up a special puller along the lines used to remove the grinding wheel and hub from a surface grinder similar to the one shown here.
    https://www.practicalmachinist.com/v...s-dscf0020.jpg
    found in a Google image search.
    P.S. I can't get any pictures at the moment but my Matheys shown at the bottom of the page on Tony's site,
    Matheys Semi Jig Borers & Millers has the front pulley held on to a taper with a special nut in the centre as described above.
    You can't see the nut in the pictures but you can see the socket cap screws on the retainer for the short upper spindle bearings below the pulley that may be similar to the ring you removed on yours .
    Regards,
    Jim
    Sep 2018
    Rhode Island
    After further investigation, there was a small access hole on the underside of the plate under the pulley. The pulley was held in with 4 small screws that attach the pulley onto a brass ring. The plate has a shaft sticking up with a bearing that the pulley rides on.
    Once I found the 4 screws the pulley poped of no issue. But dam those were hidden.
