Greaves Klusman Lathe - Page 4
Page 4 of 4 FirstFirst ... 234
Results 61 to 62 of 62
  1. #61
    Aug 2014
    lennox, sd, USA
    222
    91
    207
    Quote Originally Posted by rj1939 View Post
    You referenced "hammer the job", were you referring to hammering the babbit? What was the purpose of that?
    If your referring to peening the Babbitt, I dont believe Tyrone was talking about that but I may be mistaken. Peening Babbitt is done whenever its poured over a material which doesn't tin, such as cast iron. Steel will tin so the babbit sticks to it, but with iron the Babbitt shrinks when it cools pulling away from the base material. A good Babbitt pour will include peening the Babbitt to open it up and spring it back against the housing before its line bored. Keeps the bearing tight and once machined you cant tell it was done. Hope that's what you were asking.
  2. #62
    Jan 2008
    southern il
    838
    138
    288
    Quote Originally Posted by ironsmith89 View Post
    Yeah, that pretty well answers it. I've seen "dimples" or some kind of method for the babbit to hang onto, in castings.
