PeterH48
- May 3, 2006
- New England
I recently picked up a Hammons Model UBG-622 belt grinder. It powers on and works fine, but there is something going on with the belt tracking on it. The machine came with no manual, so trying figure it out. If you try to adjust it while it's running, by slowly turning the knob, the belt moves slowly to a certain point, and then it just jumps all the way to the left. The wheel that adjusts is steel. It rides on a rubber wheel on the other end. Both wheels are nice and tight with no wear or movement. The belt itself has seen better days and I am going to get a new one as the surface it rides on is pretty glazed. Any chance someone has this machine? On my band saw, once you set the blade to track where you want it, you lock it in place. On this machine, I don't see any means of locking the setting. It's like it relies on the pressure or tension on the belt to hold the setting. Any help or suggestions would be appreciated. Would be nice to find the manual for it, but so far no luck. Allot of Hammons literature at Keith Ruckers site, but not so much on belt sanders. Am leaving tomorrow and will be gone for a few weeks, but will be checking this post while away for any responses. Thanks
