An excellent and valuable video presentation.
Ben Russell and I have aired some aspects of this instrument, and one of the things that came up was the possibility of it being hastily made to test a concept. However, Mr Francis has noted wear on the moving anvil, which seems to suggest that it wasn't just tried and quickly abandoned.
If it was made to test a concept, then it was presumably not intended to 'sell' the idea to anyone else. Otherwise it would surely have been given more user-appeal, by putting numbers on the dials, and having just a single pointing hand on each dial. More likely that it was made as a prototype to allow the designer to identify the pros and cons.
Even if the workmanship had been very good, rather than very poor, it would have disappointed as a precision measuring instrument. Too much friction, no sensitivity, too much scope for lost motion. Bizarre anvil shape - poor even for measuring flat plates, useless for round items.
And the workmanship is poor. And not because it was made in a rush. If that was the case, why go to the trouble of making the frame U-shaped? Much easier to have square corners. Why bother putting a decorative radius on the top corner of the frame and the gib? It’s hard to see how any moderately skilled worker could have turned out such work, unless he was ‘not himself’ at the time.
From what I’ve seen of Watt’s commercial instrument work, and in truth I haven’t seen much, the standard of workmanship is by no means pleasing to the eye. A bit slapdash in places, but far better than we see in this micrometer. Also, it is known that Watt was capable of doing precision instrument work. He made a dividing engine in 1772, and by 1774 had improved its screw to the extent that it ‘did not err the 1/200th of an inch’ in 9 inches [Letter from Watt, quoted in Richard L Hills’ ‘James Watt’ Vol 1].
What was the designer’s motivation? Presumably to provide an instrument for end measurement, in which the use of dials offered the possibility of rapid readings with reduced chance of ‘operator error’ (compared with the alternative of sliding calipers with a tiny vernier). What items it was intended to measure is another question.
The idea that the instrument might have been made in the 19th century as a ‘spoiler’ to imply priority over Palmer’s micrometer can be dismissed out of hand. This is a bench instrument, bearing no meaningful resemblance to the familiar pocket micrometer.
In passing, Palmer’s concept was brilliant: a small highly portable instrument with the ingenious concept of putting all the graduations on a compact sleeve and thimble. My impression of the quality of Palmer’s early micrometers – admittedly only from photos – makes me doubt that they could have reached the standards of accuracy that we expect now, and in fact were achieved very early on by Brown & Sharpe
