Hardinge Quck Change HS missing parts
Likes Likes:  0
Results 1 to 3 of 3
    Oct 2018
    Virginia
    174
    51
    50
    Default Hardinge Quck Change HS missing parts
    I wondered why I had so much end-play. Took the HS apart on my lathe and it looks like the thrust bearing is mostly missing. I think what I'm seeing is one of the races.
    I noticed the part that holds the bearing has been repaired too. I suspect someone broke it trying to get it to unscrew. Does the bearing just pull out or is it fastened in some way?
    Someone, instead of fixing the bearing, used a large washer between the end of this part and the bearing holder. It works sortof.
    Mar 2011
    Niagara-on-the-lake, Ontario, Canada
    575
    18
    69
    Ill send you an email with some info.
    Harold
    Oct 2018
    Virginia
    174
    51
    50
    Thanks for the email and the information.
