TomBoctou
Hot Rolled
- Dec 29, 2007
- Boston, MA, USA
I've got a Hardinge TL lathe that I've had around for a while but never gotten running properly.
The motor's an Allis six wire dual speed 0.75/0.375hp 220V three phase, 21W frame, type "OMS" (what's OMS?). I'm running it off 208 Y from the street, not a phase converter.
The motor runs, I can't tell if it's the right speed but it's not super slow, and it's strong enough that I can't keep it from starting by holding the sheave. It makes a buzzing noise when it runs, sounding kind of like a stalled motor, and after only about a minute of running with no load (not even a belt on the sheave) it gets hot to the touch and starts to smell hot.
Does that ring a bell for anyone? Could this be a delta motor running on Y? Motors are largely magic to me, but I'd think that if there was a broken or shorted wire somewhere then it wouldn't start, and the contacts in the drum switch look ok. What if it had been rewired for 440? That seems unlikely, but I'd expect that to just make it run weak (I assume the speed comes from the 60hz and the strength comes from the voltage). There are no obvious signs of someone having been inside the motor or electrics, but I wonder if it has wires mixed up so that some of the wires are high speed and some are low speed. I haven't chased down a wiring diagram to check it yet.
Any clues for the clueless are appreciated.
