HBM R.S. Stokvis & Fils
Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    9,454
    1770
    2728
    Default HBM R.S. Stokvis & Fils
    I have recently purchased this Boring Mill.
    It is a R. S. Stokvis & Fils, I for sure have never heard of the brand before, and
    will be surprised if anyone on the forum has. Unless by coincidence they worked in
    the shop where this one was. I'm guessing I'm not going to find any parts for this
    on EBAY or Walmart...not even in the auto care isle...
    The model is a AFMF 80. The manual I have is sparse, more like a sales brochure.
    Overall dimensions as follows:
    17' X 8'3" X 8'5" LXWXH
    35.5 X 44.25 Table working area in inches
    3-1/8 Spindle Dia
    MT #5 taper
    Seems odd that the machine supposedly was built in Belgium? but the manual
    lists dimensions and travels in inches, and then shows thread cutting ability in Metric and Whitworth.
    I've re-read the HBM in Charlotte thread with much increased interest, and appreciate
    the info on spindle tapers posted there.
    http://www.practicalmachinist.com/vb...rlotte-281924/
    There is NO tooling included, and no "tail stock" or "outboard support", whatever it's called. although the base for it is parked at the end of the ways......a start anyway!
    As things, go the first job I do on it will require the outboard support, and I'll have to go to great lengths and effort to fab something, never to use it on another job again....lol.
    I am now keen to locate some spindle tooling, and a nice big, (cheap), angle plate would be great!
    Jun 2013
    Washington
    683
    272
    517
    Very interesting. Have you found any information about the manufacturer? Found this during a quick search. I skimmed thru it as it is a lot to read.http://www.leagle.com/decision/19443...%20CORPORATION
    Jan 2002
    9,454
    1770
    2728
    I did Google the company and that was about the only thing that came up.
    Apr 2006
    Manchester, England
    9,159
    1500
    6109
    Err, that looks very much like a Belgian Forges De Gilly Hor Bore machine to me. H R Stokvis & Fils could be a dealer or agent.
    Regards Tyrone.
  5. Likes Matt_Maguire, dkmc, sable liked this post
    Jan 2002
    9,454
    1770
    2728
    Quote Originally Posted by Tyrone Shoelaces View Post
    Regards Tyrone.
    Yes, the bad photocopied manual shows that name on the side of the base casting.
    Maybe it's painted over?
    Jun 2013
    Washington
    683
    272
    517
  8. Likes Billyum, Dupa3872 liked this post
  9. #7
    Sep 2004
    south SF Bay area, California
    2,157
    201
    746
    dkmc --
    I'll concur with Tyrone Shoelaces on this; the "FG" on the column in your second picture is identical to the "FG" I've seen on Forges de Gilly HBMs of "a certain age". The "FG" images in the attached links are slightly obstructed, but I think enough shows for you to make your own comparison:
    1 FORGES DE GILLY AFMF100, 100, 1025 - Machine Tools - Second hand machinery - Wotol.com
    https://www.apexauctions.co.uk/aucti...tm?lotId=88735 (Picture 2)
    I'll go with the riveted-on tag being a dealer's tag.
    John
    Adding a bit more: A search engine turns up R K Stokvis and Sons as a British company, while the Dutch wikipedia has more information about the company that I think you'll find interesting. http://nl.wikipedia.org/wiki/R.S._Stokvis
  10. Likes dkmc, cncFireman liked this post
  11. #8
    Jan 2002
    9,454
    1770
    2728
    7 posts, and learning a LOT!
    Thanks to all!
    I must add.......that large red FG on the column did make me wonder...
    As for those in the posted links.......all with their bases for the outboard supports,but no mention or
    picture of the upright component!
  12. Likes JoeE. liked this post
  13. #9
    Apr 2006
    Manchester, England
    9,159
    1500
    6109
    Hi dkmc, it's not usual to find the outboard support missing. If the support isn't being used regularly it can be a handicap. On big machines that need to be loaded by the overhead crane it can get in the way and is therefore prone to collision damage. Then it gets removed and put in a corner under a small sheet somewhere.
    When the machine gets sold on the outboard support often gets left behind.
    Good luck with the search for the line boring bars. If I had a £5.00 note for every one I've seen thrown in the skip ( dumpster ) I'd be pretty wealthy.
    Regards Tyrone.
  14. Likes Matt_Maguire, dkmc liked this post
  15. #10
    Mar 2005
    near Rockhampton, Queensland, Australia
    5,560
    445
    2098
    It is probably the same size as the one that was/is for sale near me..
    Horizontal borer Forges de Gilly
    If you are wondering what the round support bar above the facing head is for... It is for attachment of a vertical head..
  16. #11
    Jan 2002
    9,454
    1770
    2728
    Thanks!
    There is actually a page in the literature I got that shows attachments.
    The milling attachment is shown there as well.....quite interesting.
    Quote Originally Posted by RC99 View Post
  17. #12
    Jan 2005
    The Netherlands
    6,612
    357
    1887
    Stokvis was a well known Dutch compagnie founded in 1849 and it owned the French Stokvis division
    It traded in all kind of technical items like bikes cars machines lubricants
    In the Dutch Wikepedia there is a artical about the compagnie
    Here is the google translation
    https://translate.google.com/transla...-text=&act=url
    Peter from holland
  18. Likes dkmc, JoeE. liked this post
  19. #13
    Apr 2006
    Manchester, England
    9,159
    1500
    6109
    Hi dkmc, look on the bright side. You've got a built in facing slide. That's a great asset on any Hor bore.
    Regards, Tyrone.
  20. #14
    Jan 2002
    9,454
    1770
    2728
    Regards, Tyrone.
    I agree with you completely Tyrone, and was thinking about that.
    I wonder why other brands do not include the feature?
    But I am really glad that after years of various levels of interest and searching,
    the one found and coming home to roost -has- that capability.
  21. #15
    Apr 2006
    Manchester, England
    9,159
    1500
    6109
    Obviously when you have a machine with a spindle running within a spindle as in a built in facing slide machine there are compromises to be made. A spindle only machine will normally have a better milling performance than a built in facing slide machine.
    Given that I'd always have a built in facing slide machine over a spindle only machine for normal jobbing shop work.
    Regards Tyrone.
  22. #16
    May 2007
    Massachusetts
    1,470
    534
    1277
    We do all small work but I don't know what it is about me that I have this constant desire to go big. I just love the idea of ripping into a 1/4 deep cut and see the chips springing off the tool and piling up. The sounds and smells of heavy iron being turned into the things we sell just make me feel like what we do is special, and it is.
    My first real job in a factory was back in the early 80's and they had just installed a huge Mazak horizontal. That machine would produce chips the size of golf balls. I was mesmerized by it and would hang around during my lunch brake just to watch it cut castings.
    I wish you the best of luck with your new mill.
    Make Chips Boys !
    Ron
  23. Likes Paolo_MD liked this post
  24. #17
    Jan 2002
    9,454
    1770
    2728
    Thank you Sir.
    Big work:
    I have a small Bullard (24") that sat for years, and almost got scrapped when scrap was high.
    (I would still be kicking myself if I sent it off).
    Along came a couple customers, and the lowly...lonely Bullard became the
    star of the show of sorts. And the 2 Gisholt Turret Lathes from 1944 had their days again as well.
    Larger pieces and looser tolerances...with some specialized repair type work too.
    It was fun really.
    Admittedly, things have gone quiet with that work now.
    But I bought the Gilly right, and I feel there will come a time when it has it's day too.
    Probably more useful than the Bullard.
    Quote Originally Posted by overflow machine View Post
    Make Chips Boys !
    Ron
  25. #18
    Mar 2005
    5,560
    445
    2098
    Quote Originally Posted by dkmc View Post
    You are making me thinking of the one that was for sale near me...
  26. #19
    Jan 2002
    9,454
    1770
    2728
    I am (also) intrigued with the idea of using the machine as a large, light duty lathe. For that, a tail stock-outboard support would be required.
    I have been asked in the past to turn down the OD of pipe, in the 24-36" size range.
    A turn of 10-12" length on the end of a 4' or 6' piece. Maybe .180-.250 step down in the diameter or so.
    I wonder how feasible this idea is?
    ...I have this 16" 3 jaw.....it's currently a D type mount.......hum...
    EDIT
    Wish I could change the title of this thread to the real name of the machine...now that I know it (thanks to members posts here).
    But the dealer name and title is set forever in eternity I guess.
  27. #20
    Jan 2002
    9,454
    1770
    2728
    Update:
    It arrived one week ago. All I've had time for is to unload it, coat it with oil and
    tarp it.
    The neighbors generously allow me to play with their large forklift.
    That's OK, I've administered a machining fix for it a time or too as well.
    One hand washes the other...as they say.
    I -almost- didn't bring the fork extensions with it...and I would have been in trouble.
    Note to self: ALWAYS bring the fork extensions no matter if you think you need them or not!
    This was not like this in the photos shown in the advertizement, but it WAS like this when I went to look at the machine. I looked but not close, I think it may be
    flat glass....I hope!
    Closer look at the facing head....in the sunlight.
    I am excited to have this new toy...er....tool...
    (to be continued)
  28. Likes stephen thomas, RC99, paul39, Billyum liked this post
