Froneck
Titanium
- Dec 4, 2010
- McClure, PA 17059
I've bored many soft jaws in 3 jaw chucks using a plate with 3 socket head cap screw that fit into the cap screw holes in the jaws. However the basic problem with 6 jaw chuck is the fact 3 sets of jaws are 180° opposite so that as soon as one pair is tight the other 2 pair are still loose. Precision ground shaft will be held but an out of roundness results in gripping by only 2 jaws. Checking the cap screw hole in the jaws with a hex head cap screw I find that the diameters are not all exactly the same. How do I support the jaws to bore them? I did try by putting 1/32" thick plastic strips between the jaws since the jaws are almost completely closed but ground shaft put in jaws has .003" change in TIR when moved 1-1/2" left/right.
