Froneck
Titanium
- Dec 4, 2010
- McClure, PA 17059
My customer uses 1-1/2" SS 304 square shafts to drive conveyer belt sprockets. OAL 47", one side is turned 1.250 X 5" (no problem) other side same diameter X 15" (Problem) I set them up in P&W 16" newer Model C lathe, I chuck the square in 12" 4 jaw chuck, measure back 15" and indicate the flats of the square best I can due to material is not perfect square. Center drill the end. Cut to about 1-3/8 diameter with CNMG6** insert. No problem but when I remove the center stresses in the shaft move it sometime over 1/8" or more. Sometime the stress is so great it moves so that the square side I just indicated is running quite a bit out. (1/4" TIR.)
The lathe has the power to cut the square round in one cut and done on the short side. But on the long side I take a light .050" and when I notice the square running out remove the shaft. Chuck the the 15" side in another 24" lathe and straighten until it runs reasonably well. Re-chuck in P&W take another few cuts and have to straighten again. Seems like every time I straighten then re-cut it returns to where it was prior to straightening. After getting to 1-3/8" OD I put the shaft between centers and find it running out quite a bit and straighten again. taking .010" total cuts, I get 2 passes before the shaft about 2" from the live center is running out. Cutting with DNMG 55° insert. Again every time I straighten the shaft it returns back to the same amount of run-out after .020 removal. Thought now the square shaft is running out due to holding between centers. Is there anything I can do to lessen the run-out without sending the shafts for stress relieving?? Being it is a poultry plant shaft requirement is NOW! They need it yesterday! The Idler shafts 137" length cut round 1.250" X 5" both sides are easily done with no need to straighten.
