Hangingfor8:
Hendey Lathe No.28650, a 12 x 30, 12 Speed Geared Head model, was completed on April 8, 1935. The following information is taken from the
original Order Form. My annotations are in parenthesis.
Date Ordered: March 26, 1935
Date Started: March 27, 1935
Sold to: Hyatt Bearings Division
General Motors Corporation
Harrison, New Jersey
Via: Truck
Wanted: April 8th
Sold by: NY (New York)
Description: 12" x 30" - 12 Speed Geared Head Lathe CR (Compound Rest) - Raised to swing 14-1/2" (RS Model)
Oil Pan
Regular Equipment (as shown in catalog)
Plain Bearings - Multiple Splined Shafts
Taper Attachment
Drawing-in Attachment and set of 13 - #3 Collets 1/8" to 7/8" by 16ths Complete with Cabinet
Furnish and Fit 12" 4-Jaw Cushman Steel Body Independent Chuck
Furnish and Fit 9" 3-Jaw Cushman Steel Body Universal Geared Scroll Chuck with two sets of jaws
Arranged for Belt Connected Motor Drive with Motor in Cabinet Leg
Furnish and Fit 3 HP G.E. Motor Type K, Frame 254 - Totally Enclosed Fan Cooled Ball Bearing
440 Volts, 3 Phase, 60 Cycles, 1200 RPM
Furnish and Fit Cutler Hammer Automatic Reversing Control Starter 9589H203 - Type AAA, Group IV Horizontal
Across the line with enclosed safety switch, fusible
Furnish and Fit Monitor Control #9002V1 Stop and Start Push Button Station
Lathe to fitted with Latch Lever Handles for the feeds and automatic lubrication to the Apron
Belt 7'4-3/4" x 2-1/2" Wide Crowflex Single
Compound Rest Parts List A12-0231
There are very few Patterns, Castings or Repair Parts left in inventory for this lathe. All of the original drawings are still in the
files, so parts can be made if required. NOTE: During this time period, Hendey installed the Apron Oil Pumps internally and they are not
accessible from the outside. If your lathe has this model pump, it will be necessary to remove the Apron to service it. Also, IF your
lathe uses Lever Type Clutch Handles instead of the Cam Type Handles, I would recommend that you buy a copy of the assembly drawing
before you try to service the Clutches. The drawing will help you located the hidden screws that are not obvious and save you damaging
the Clutch mechanism. There have not been any parts in stock for this type of Clutch for over sixty years, so you don't want to break
anything.
Hendeyman
