I cut my first chips on my Hendey today after a 10 month long restoration. My lathe is a 12 speed model but has the two speed motor option. Top speed is 1195. The headstock sounds very quite in all ranges. When I engage the intermediate gear to drive the QCGB the lathe has a lot of gear noise. I played with the backlash some and reduced the noise a little by increasing backlash a little. I cleaned out all the teeth on the gears during the restoration and I have oiled them. The open gears all spin freely. The noise isn’t to bad below 600 rpms. The QCGB has a range level 1,2,3 and then all the change gears. Based on how the lathe sounds I assume you aren’t supposed to use ranges 2 and 3 except for threading at low spindle speeds. I barely engaged the spindle clutch and wow was it loud in range 3 at 600 rpm. Is there any info on what spindle speeds are acceptable to have the feed system engaged? Say I wanted to turn a 1” round spinning 1000 rpms, am I limited to hand feeding? Any general guidelines regarding this? I’m coming from an import 12x36 Birmingham lathe.
