Hendey 12x30 Motor mount
Hartkem
Jun 6, 2019
Can anyone take a picture or describe how these parts are supposed to be assembled for the motor mount? This lathe is a 12 speed gear head with a two speed Westinghouse 3 phase motor.
Unless someone beats me to it, I'll look at mine tomorrow morning and post some pictures if it looks similar.
Sent from my Nokia 7.1 using Tapatalk
Thanks. I also have the 18 speed version but it seems different.
First rectangle, then spacer, then washer, then nuts. Tension the belts, then lock the nuts together.
There was a rubber piece between the spacer and washer that I assumed was added by a prior owner. There was also one under one of the two square headed bolts that lift the motor plate. Is there any factory rubber isolation? I would think the motor weight alone would more than provide the necessary belt tension.
Not sure, but I doubt it’s original. Between the square head bolt on the right and this one, the whole thing should be pretty tight.
Sorry, I had to leave town and didn't get to the shop. I won't get out there until Thursday am.
