Binder791:
Hendey Lathe No.29560, a 14 x 42, 18 speed, Geared Head model, was completed December 14, 1937. The following information is from the
original Order Form. Information in parenthesis is my addendum.
Date Ordered: June 2, 1937
Date started: June 9, 1937
Sold to: Frigidaire Division, General Motors Corporation, Dayton, Ohio
Ship to: Above, Plant #1, Dayton, Ohio
Via: Freight
Marks: Deliver to #582 Hood
Sold by: K.F.K.
Description: 14" x 42" - 18 Speed Geared Head Lathe CR (Compound Rest) - To swing 16-1/2"
Oil Pan
Regular equipment (as shown in catalog)
Ball Bearings on main shaft- Multiple splined shafts
Cam Lock type flanged spindle nose
Spindle Speeds - 19 to 1000 R.P.M.
High speed reversing mechanism
Taper attachment
Drawing-in attachment and set of 29 #6 collets from 1/8" to 1" inclusive by 32rds complete with cabinet
Furnish and fit Cushman 15" 4 jaw independent chuck #15214D6
Furnish and fit 15" 3 jaw universal chuck #15236D6
Arranged for vee belt connected motor drive with motor in cabinet leg
Fit motor and starter
Furnish and fit Hendey push button built into gear box
Delco ball bearing motor, 3 HP, 440 volts, 3 phase, 60 cycles, 1200 RPM, model I-1350, frame 254
together with starter K-9998-B-23
Starter will be Delco #1262 non-reversing combination type
Hendey push button will be for non-reversing service
Friction type clutches in apron
There are very few Patterns, Castings or Repair Parts left in inventory for this lathe. All of the original drawings are still in the
files, so parts can be made if required.
Hendeyman
