Hendey 14x54 lathe info
Likes Likes:  0
Results 1 to 4 of 4
    Feb 2021
    North Carolina
    Default Hendey 14x54 lathe info
    I've recently acquired a Hendey 14x54 lathe and trying to get more info on it. I've been told @hendeyman here is the guru when it comes to these lathes. The serial number stamped on the plate is 18532, I also found numbers on top of the gear box underneath the lid that are 40 63 027. Any info, manuals or literature on it would be greatly appreciated.
    Edit: located the correct serial number, it's actually 32749
    May 2007
    Yadkinville, NC
    165
    The serial number should be stamped into the bed casting as per the photo instead of a plate. 18532 would be pre 1920 but at that time the bed length was measured in feet instead of the center distance capacity in inches.
    Feb 2021
    North Carolina
    I had emailed hendeyman and he told me where to locate the serial number. What would be the number stamped on the part at the gear box I wonder?
    Jul 2004
    Houston, TX USA
    32,115
    Any actually marked 14 X 54 will be later 12 or 18 speed
    Here is that manual scan
    http://pounceatron.dreamhosters.com/...dey-Op-Man.pdf
    have fun
