Hendey clutch noise
Results 1 to 5 of 5
    Jul 2011
    Australia
    138
    7
    16
    Default Hendey clutch noise
    Hi
    My 1940 12 X 30 Hendey has a loud noisy clutch , I have tried adjusting the clutch by unlocking the ring and moving the ring both ways but the noise won't go away . It sounds like something is grabbing or hitting another part like a vibrating effect. Its the multi disc clutch like this one , everything appears unworn, the four rings are like new . I have lubed the drum bearings so the drum spins freely . Don't want to pull off the whole assembly but I may have to. Thanks Mike in Australia
    Jul 2004
    Houston, TX USA
    30,729
    In case the manual page is hard to read
  3. Likes Sheraton2 liked this post
    Jul 2011
    Australia
    138
    7
    16
    Default noise
    Ok I have made some progress. I think the noise is mainly due to how the clutch is designed. When the clutch is engaged the four slip rings are free to wobble and this creates a annoying sound. But When the rings are tight against each other and they are driving the headstock, the noise disappears. Are these rings supposed to be oiled ?
    Nov 2005
    elfrida arizona usa
    1,355
    481
    Sheraton:
    The Twin Disc clutch that you and John Oder posted a drawing of is not the model that is in your lathe. The Clutch in the
    drawing is an MT4 and the clutch on your lathe appears to be a 4030, 4 inch Model C-C. Later charged to a 4030SC. This
    clutch was made especially for Hendey in March 1937 and was in use until 1942, when design changes were made. By the end
    of the War, this clutch was considered obsolete.
    Regardless of whether it is a 4030 or MT4 clutch it is usually adjusted the same. Pull out the Pin and tighten the Adjust-
    ing Ring. With the Adjusting Ring snug and the Pin back in a hole, start the the motor with the clutch disengaged. For this
    test you will want to have the Adjusting Ring snug enough so that the chuck just "creep". Loosen the Adjusting Ring one
    hole at a time until the "creep" stops. Trying engaging and disengaging the clutch several times and make any adjustments
    as needed. Normally, when a Twin Disc clutch is in the disengaged position there should be no play in the discs and hence,
    no noise. The 4030 clutch on my lathe has been running 80 years without a major rebuild, just minor adjustments from time
    to time. This is a "dry", the only oil required is in the Cone Collar Oil Cup. If this doesn't solve your noise problem,
    post again and we will give it another try.
    Hendeyman
  6. Likes Peter S liked this post
  7. #5
    Jul 2011
    Australia
    138
    7
    16
    thank you Hendeyman
    I have adjusted the adjusting ring up as you suggested , but after I do that the cone collar won,t go all the way up against the ring , it stops half way and the clutch won't engage. I measured the gap in the four slip ring set and it has about .120" of free space when the collar is not pushing the rings together. Is there any way of adjusting the four rings gap up closer ?
