Hendey Conehead with a homemade carriage? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21
    Aug 2018
    Washington
    34
    7
    Hoo! Only thing I can think of as might bust a Hendey saddle is an overhead crane op dropping sumthin' sore MASSIVE! I doubt you could create an on-machine crash bad enough to even come close.
    Whomever was desperate seems to have had the remains of that, as parts of it were re-used.
    One might guess "wartime" and few other options to be had?
    Probably CAN turn out better work than an HF LSO, even crippled as it is, but still..
    If the dream is A) a new casting, B) salvage from a partout, fitted-up.. what's your "plan C"?
    My guess on the broken saddle/everything is that it was being moved and got dropped on it's face.
  2. #22
    Aug 2018
    Washington
    34
    7
    Last question... the threads on the big end of the big bearing, and the ring nut that goes with it, are badly called. If I'm not able to get the backlash se properly, what is the suggested material for making a new bearing and ring nut?
  3. #23
    Jul 2004
    Houston, TX USA
    31,236
    Any idea what the taper is in the tailstock? Opening measures roughly 1.25". What about the headstock? Is it standardized in some way that I could get a faceplate and center, or a 4 jaw?
    16" Early twenties catalog page says.....
    Tail Stock is #3 Morse Hendey taper. May have been opened to MT 4 by now - which about 1.25 on big end
    Head stock thread is 2 1/2 - 6 - the only "standard" this is is Hendey's, and no, you don't have much recourse except make a back plate to fit, and bolt a flat back chuck to it. You won't "find" one that fits unless it is off an identical Hendey
    Same catalog page states the spindle taper is 4 1/2 Morse Hendey
    If the Post # 22 about the threads being galled are related to SPINDLE, this may be your first findings on a very common old Hendey spindle binding issue - about which there are MANY posts
  4. #24
    Virginia
    15,254
    7561
    10499
    Quote Originally Posted by jimsnell View Post
    Google this: site: practicalmachinist.com "hendeyitis"
    Get the end-thrust sorted, you can probably save the one you have. See also "thread restorer file".
  5. #25
    Aug 2018
    Washington
    34
    7
    Quote Originally Posted by johnoder View Post
    Definitely has hendeyitis.
    The chuck thats currently on it is a flat back. Suggesting that I just make a face plate to match? How would I come up with a center to match that Morse Hendey 4 1/2, when i don't have either a taper attachement or a set of centers to do an offset tailstock?
  6. #26
    Virginia
    15,254
    7561
    10499
    Some of these things CAN be "bootstrapped" with nothing obviously useful to start with and the damndest of farm-boy techniques. They had to be before communications and shipping got universal, affordable, fast, and easy.
    Not worth it in the internet age.
    Lay by some cash or trading material. Identify what you need first as accurately as you can do.
    Ask for very specific help, one insoluble "opportunity" at a go.
  7. #27
    Nov 2005
    elfrida arizona usa
    1,379
    567
    jimsnell:
    A No.4-1/2 Morse Hendey Taper is the Spindle Taper, not the size of the Spindle Center, which is a No.3, the same as used in the Tailstock. All you need is a Center Bushing, which is basically a reducing bushing, No.4-1/2 to a No.3. I will look around the shop, I may have a spare. If not, next time I am grinding Centers and Bushings, I could make one for you.
    Hendey Spindle Thread sizes are only nominal and should be used for reference only. In most cases the Spindle threads are about .025"
    under the nominal size. As johnoder has stated, a standard 2-1/2" - 6 chuck or face plate will be loose on a 2-1/2" - 6 Hendey Spindle.
    If you could find a Driving Plate for your lathe, it would make a good Back Plate for a chuck. It would still require a bit of careful
    machine work to make certain that everything was concentric, but it would be a lot easier, considering the condition of your lathe, than
    trying to cut accurate internal threads.
    Because the Aluminum Bronze, that the bearings are cast from, gets brittle with age, do not try to remove the bearings. The large bronze
    nut is primarily used to collect and return oil from the bearing to the oil cellar. They normally get damaged when someone uses a pin
    punch to unscrew them instead of using the proper pin spanner. Do not attempt to restore the Bearing Threads because in many cases they
    will chip off causing a bigger mess. If the thrust surface (the front of the bearing) is worn, very carefully draw file it to an even
    flat surface at right angles to the center line of the Spindle. Then follow the instructions in this Forum for shimming the Thrust
    Washer. If you find pitting or scoring in the Bearings, carefully dress down any high spots and provided the damage isn't extensive,the
    pits will retain oil.
    Hendeyman
  8. #28
    Jul 2004
    Houston, TX USA
    31,236
    So you will need all possible info that has assisted others to FIX this issue - it is most certainly not ADJUSTABLE
    The shimming has long worked well. Other approaches by some members forget about shimming and use such as TIMESAVER compound - used forever by the antique auto avocation to fit Babbitt bearings
    Attached Thumbnails Attached Thumbnails front-detail.jpg   all-parts.jpg   spindle-alphas.jpg   spindle-removal-instruct.jpg   list.jpg
  9. #29
    Aug 2018
    Washington
    34
    7
    Public service announcement.
    Moving a lathe without either a crane or forklift is horrible.
  10. Likes svs liked this post
  11. #30
    Aug 2018
    Washington
    34
    7
    Apologies on resurrecting a thread... This machine might be on the chopping block. If I part it out, is anyone interested in anything on it? Not looking to make any money here. It's definitely being replaced and won't have a spot in my garage anymore.
  12. #31
    Feb 2011
    2,569
    2111
    1139
    Sorry to hear, but hope you end up with a better machine. I'll have to see how close it is generationally, but I might be able to use a couple pieces for me 16" gear head Hendey. Do you have any other pictures showing the left side of the head-stock and gear-train? Mine's missing a gear cover there.
  13. #32
    Aug 2018
    Washington
    34
    7
    In a couple days ill post up an actual parting out thread.
