Hendey cross slide locking
Sheraton2
Jul 24, 2011
Australia
Hi
I hope one of you guys can offer some assistance
My Hendey cross slide lead screw is free to slide in/out of the carriage . Am I missing a part because I can't see any way of locking the lead screw to stop it moving in/out along the carriage. Thanks . The hole in the end of the lead screw mount is broken too , think its for the taper attachment but not sure.
Edit: JohnNoder said this " Sliding block is clamped by a long set screw thru rear carriage saddle wing from the side "
So there is a long bolt that goes in from the rear carriage wing , from the side ?
Sure is - square head, usually from wing nearest tail stock
You can sort of see it here
As an aside slop in cross slide screw is often from maladjusted thrust bearings on each end of that thrust block - of course its next to impossible to get to the nut on the end of the screw in this area
And you have an extra "N" here
JohnNoder
Here is a pic of the river that we suppose is where the name came from
