HendeySwede
- Mar 31, 2018
A couple of years ago I bought a Hendey for 500 USD. The removal of a thick layer of dirt revealed a geared head 18 speed 14x42 lathe with a TRB camlock spindle. Being only an amateur it took me a while with the help of the operators handbook (supplied by Tony Griffiths, UK) to figure out all the clever devices this machine is equipped with. Friction drive for feeds , quick release levers, apron reverse mechanism and quick withdrawing handle were some of the things that were new to me. The ways are worn and there is a bit too much play in the feed screws and half nuts but I have still managed to turn both big and small end conrod bearing bushings to hotbulb engines with acceptable tolerances. It is a joy to operate this fine machine though some of the lower speeds are a bit noisy. Apart from cleaning, I have only changed the oils and opened up clogged oil pipes. The machine now happily pumps oil everywhere and leaks a bit too much from the spindle ends and apron. Frequent wiping-off is needed . If I decide to dismantle the head and apron I will do something about that.
Finally to my question: Does somebody know something about the history of this lathe and how it ended up in Sweden?
The serial no is 29409. The machine is fitted for metric markets with 5 mm lead screw, mm indexed feed screws. The thread index plate shows metric threads and the wording is in french. The electric motor is a Swedish 5 hp ASEA 380V 3 phase , professionally installed.
Hendey lathes are relatively unknown in Sweden were the market was dominated by local manufacturers such as Storebro and Torshaella. British Myfords and German Weilers were also quite common here.
Grateful for all information, and, almost forgot, tks a lot to all of you out there, Clemwyo and others, for posting fantastic videos on the net.
Hendeyswede
Hendeyswede
