Peroni
Cast Iron
- May 18, 2007
- Yadkinville, NC
Recently rediscovered this photo and thought I'd see if anyone has come across something similar before. This Hendey was one of two that were at an east TN auction several years ago. As far as I know this lot went unsold and I've not been able to find out what happened to it. Only one photo was provided and no serial number was listed. The other lathe that sold was your typical later T&G with standard motor gen drive.
The lathe itself looks to be a standard 9x24 tool and gage model. What I find interesting is the lathe's drive system. It looks to be a motor/gen drive but it's different than anything else I've seen published. There's a small lever next to the push button station, the tags are hard to read but I believe they say GEAR and BELT. Yet the lathe itself has the typical large lever for shifting between gear and belt drive and is still labeled as such. There is another lever next to the speed rheostat that looks unmarked. Perhaps the on/off switch? Headstock casting has the boss for where the switch lever should be but it's not machined. Lastly the speed rheostat appears different to the typical one seen in published literature.
Does anyone own a Hendey with this drive cabinet handle layout. Hendeyman do you have anything to add? Mostly looking to satisfy my curiosity here.
