Hendey Tool & Gage Restoration
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 83
    Aug 2017
    105
    20
    29
    Default Hendey Tool & Gage Restoration
    Today I picked up my Hendey Tool & Gage Lathe, #30757. I spotted this on our local Craigslist last week, the seller had been planning to restore it but decided to sell due to moving out of state. It's in pretty rough shape but the price was right. I have been looking for an upgrade for my Southbend 10L and this will be perfect.
    Unfortunately the front doors are missing, it does have the side and rear doors, and taper attachment. The tailstock is not in the photos but it's there, also got a 3-jaw chuck, face plate, couple other things. It did not come with a steady or a follower.
    There are a few missing gear teeth somewhere in the apron, and most of the knobs are frozen solid. There is some wear on the ways - I'd guess 0.010-0.020 but I'll know better after I get it cleaned up. This is going to be a huge project, but I'm looking forward to it.
    If anyone is parting a T&G, please PM me, there will be a few things I'll need.
    Hendeyman, I will be very grateful if you can give me any information about my machine. Thank you!
    Attached Thumbnails Attached Thumbnails img_1683.jpg   img_1691.jpg   img_1692.jpg   img_1695.jpg   img_1697.jpg
  2. Likes morsetaper2, M.B. Naegle liked this post
  3. #2
    Aug 2017
    105
    20
    29
    Last weekend when I first saw the lathe I was disappointed it was missing the steady rest, because I knew it would be hard to find. And the followers are unobtainable. But I left the deposit, went home, and searched ebay for "hendey". And what do you know...
    It was definitely premature to buy these given the condition of my machine, but I knew it was my only chance. Totally lucky actually... hopefully I can get the machine running and get my money's worth from these.
    Anyone want measurements or anything? I might consider doing a run at Cattail foundry at some point, if it's feasible to use an original as a pattern.
  4. Likes M.B. Naegle, ncjeeper liked this post
  5. #3
    May 2003
    Lambertville, MI USA
    2,578
    1077
    1153
    Did you get a tailstock with it?
  6. #4
    Jan 2010
    NH, USA
    126
    30
    26
    I can send you the door to the piv drive, and if you need other piv parts I can see what I have. PM me an address and I'll send it out.
    Mark
  7. #5
    Apr 2013
    Damascus, MD
    1,447
    4167
    819
    MY suggestion is that, before accumulating spare parts to fix it, make sure that it is worth fixing it and not better used as part donor itself. Check if all the gears are sound, if the apron is in good shape and everything inside there works fine, check the actual wear on the ways, etc.
    I understand that you live in a machinery desert. But, sometimes, it makes more sense to buy a second machine sight unseen from far away and have it shipped to your place overall for less than what you would invest in trying to fox this one (it's true that this model is not extremely popular. But, especially because of this, think twice, before investing too much into it.
    Paolo
  8. Likes Kjelle liked this post
  9. #6
    May 2011
    Toledo, oHIo
    298
    512
    110
    .010-.020 wear on the ways!?!?!?
  10. #7
    Aug 2017
    105
    20
    29
    Quote Originally Posted by SIP6A View Post
    Yes, I took it off for the move and forgot to put it back for the photos.
    Quote Originally Posted by M.Latham View Post
    Mark
    That is very generous, thanks for the offer. Do you mean the cover to the PIV itself? In that case I do have it already. Not sure why it had been removed though, so I expect I might need some spare parts eventually.
    Quote Originally Posted by JBoogie View Post
    I just measured and the wear is about .003. I guess I'm pretty bad at estimating wear by eye.
    Most of the black grime is scraping right off of the metal surfaces. There is a little rust but it's not that bad.
  11. #8
    Aug 2017
    105
    20
    29
    I dug in a little bit today. Overall the rust and wear is not too bad, my Southbend was worse. There is grime and petrified grease everywhere.
    The pinion is missing three teeth, as I had expected. The halfnut is a little worn but not too bad. I made the mistake of pulling the pinion stud without marking it first - didn't realize until later it was on an eccentric. It was probably due for readjustment anyways.
  12. #9
    Jul 2001
    North Carolina
    1,971
    178
    407
    If you decide to scrap it
    I would like to buy your steady
    and follower rests.
    -Doozer
  13. #10
    Virginia
    27,803
    7561
    8640
    Quote Originally Posted by Doozer View Post
    and follower rests.
    -Doozer
    ?? "If he decides to scrap it", lots of folks would be happy to take the whole shebang, and not all that cheaply.
    Not that I see any reason it is even a candidate for "scrap" to begin with.
    Probably the closest "stateside" competitor as ever was to a Monarch 10EE that actually SHIPPED in any quantity.
  14. Likes Hopefuldave liked this post
  15. #11
    Feb 2011
    2,219
    1625
    945
    Doesn't look like to big of a project. Even worn out, it'll have better rigidity than a South Bend. I'd prefer to find an old Hendey T&G lathe than a Monarch, but I have weird taste too.
  16. Likes Hopefuldave, Herb in Delco liked this post
  17. #12
    Aug 2017
    105
    20
    29
    Thanks, Thermite. Yeah I'm not scrapping it, or parting it out. Internally it is in pretty good shape (other than the pinion). I have been inside the gearbox and headstock and inspected every gear. Almost everything is moving now. And there isn't much rust -- at least not where it counts. It's just dirty.
  18. Likes shapeaholic, Herb in Delco liked this post
  19. #13
    Virginia
    27,803
    7561
    8640
    Quote Originally Posted by M.B. Naegle View Post
    Warsh your mouth out with brown laundry soap for even putting that Iron-deficient hobby-noodle on the same page as ANY Hendey!
    Otherwise, yah. I even BOWED to the first one I set eyes on. Ask TRboatworks!
    So not exactly "weird taste". You might simply be queer for PIV drives?
  20. #14
    Oct 2003
    CANADA
    Ontario
    1,187
    75
    121
    Default Been there done that😏
    I'm not sure how far along the line hendey started to use hardened bedways, but I can tell you from experience rebuilding my T&G that if they are hardened the only way to go is bed grinding.
    My lathe was worn considerably, and also had a small twist. This necessitated removing 0.032 (aprox).
    Once the bed was done, considerable work also had to be done on the carriage, as it had worn more on the front headstock side. After machining I used probably 0.50-0.60" of moglice to bring the carriage back to correct height so that I didn't have to mess with leadscrew or feed rod alignment.
    Overall it took me about 3 years of part time work to get mine where it is now. Quite a bit of time was spent reviving the original magnetic amplifier drive. (Success due in large part to Cal Haines, on the monarch board)
    It is a great lathe, but if I was to put in that much effort again I'd look for a monarch 10ee, as tooling and parts are much more available.
    Peter
  21. #15
    Virginia
    27,803
    7561
    8640
    Quote Originally Posted by shapeaholic View Post
    I have a growing collection of ex-Hardinge-system tooling, most of which needs jacked-up for 10EE use.
    I'd surmise it would be closer to a drop-on with the slightly lesser swing Hendey T&G. Might want to see if any of it catches your fancy. Short ton of it around, and not ALL of it is junk, over-priced, or BOTH!
  22. #16
    Aug 2004
    Somerville, NJ
    219
    9
    I wouldn’t be discouraged by that .003 bed wear. My Hendey T&G was acquired at a tag sale held in a local tool and die shop which was closing down. Many people at the sale felt the “ridge” on the front way by the headstock and walked away. When it was cleaned up and leveled, I turned a piece of 12L14 and found about a 4 tenths taper over 8 inches. I don’t recall the exact wear but probably similar to your 3 thousands. The long contact distance of the carriage on the bed must be responsible for the minimum taper.
  23. Likes Doozer liked this post
  24. #17
    Virginia
    27,803
    7561
    8640
    Quote Originally Posted by browniesharp View Post
    Got waay more wear than that here, each 10EE.
    I want to fix it, but don't HAVE to. A bearing fit is seldom even a full inch long.
    And it IS those long lever-arm, even-wearing carriage lengths. Carriage is about two inches longer on a 10 X 20 10EE than the 20" inches it can traverse. A portion of the ways never sees daylight from new until the carriage comes back off for rework.
    A wide carriage is one of the most reliable tell-tale signs any of the "Grand-old" high-grade lathes were built to hold their numbers longer than lessers would.
  25. Likes Herb in Delco liked this post
  26. #18
    Mar 2005
    Maine
    1,325
    9
    532
    Peter
    I think Hendeyman told me were probably less than 400 T&Gs made, including the BCs.
    So parts are a little scarce, but so much more satisfying when you find them.
  27. #19
    Virginia
    27,803
    7561
    8640
    Quote Originally Posted by maynah View Post
    That isn't far off the combined count of the "big" Schaublin's totals - all sizes in that sub-tribe counted as rare, some just more so than others.
  28. #20
    Aug 2017
    105
    20
    29
    Peter
    Big project! I had my eye out for a 10ee for the same reason, but I wasn't going to pass on the T&G once I found it.
    To be honest I am glad I have the PIV drive. I'm sure the electrical drives are great, but it seems very complicated. Maybe I'll change my mind after I open this PIV.
    I think I will get the lathe cleaned up, repaired, lubed, and repainted first. I'll save the regrind for last, and maybe skip it altogether if it performs well enough.
    I wonder how many of those 400 are still around...
