Results 1 to 20 of 73
Thread: Holbrook C10 #10411
10-20-2019, 12:31 AM #1
Holbrook C10 #10411
Took delivery of serial number 10411 on Thursday.
I've never had any British iron (besides my first automobile which was a Triumph GT6+) and I'm impressed.
Needs the hydraulic oils changed and am going to disassemble the compound, cross slide and lift the saddle to clean out all the gunk and dried oil before I run it.
Has the optional turret compound.
10-20-2019, 01:55 AM #2
I'm unfamiliar with that lathe but not the word "awesome". Striking machine and looking forward to your re vitalization.
10-20-2019, 06:36 AM #3
The C series Holbrooks are very nice machines, …………….a prewar open flat belt Holbrook model T ( Holbrook Model T Lathes) was the first proper industrial lathe I used (<> age 14) .and despite its age and well used state, after the Colchesters YUK! of high school that Holly was both a revelation and love at first sight
Or as said by some, ''Holbrook ;- the thinking mans Dean Smith & Grace.''
10-20-2019, 07:32 AM #4
pressbrake1 liked this post
10-20-2019, 09:00 AM #5
That is a beauty.
10-20-2019, 09:13 AM #6
WOW! That just looks right.
"Holbrook ;- the thinking mans Dean Smith and Grace"
That should be on a Tshirt, Limy Sami
10-20-2019, 10:23 AM #7
10-20-2019, 01:39 PM #8
10-22-2019, 08:36 PM #9
10-23-2019, 05:18 AM #10
I like it!
Problem is ... so few would know whom either lot of names WERE these days ... a body might find "activists" throwing cement milkshakes at 'im on the public streets over proselytizing gay monogamy over a Menage a Trois.
Nice lathe.
But WTF? A 10EE is "complicated".
All those levers? Mindful of a B-36 cockpit. This bugger looks like it needs a co-pilot, crew chief, and a flight engineer as well as a pilot!
Mind.... simper than my HBX-360-BC. Still studying that complex creature. Its very quirks have quirks which in turn have eccentricities. Nobody does "weird" like the French.
10-24-2019, 08:52 AM #11
10-26-2019, 11:38 AM #12
That is a beautiful machine! What is the top speed of it, if I may ask?
I, too, desire a 10EE, but also stay clear due to the complicated drive systems.
10-26-2019, 01:43 PM #13
Looks like 2000
Some more specs here Holbrook Model 10 LatheLast edited by Limy Sami; 10-26-2019 at 03:13 PM. Reason: pyto
10-26-2019, 01:55 PM #14
The plain spindle bearing ones have a top speed of 2000 but the ones with roller bearings, like this one, top out at 3000.
It has a set of tiny collets that are a proprietary Holbrook size that fit into the spindle with an adapter.
Anyone know what the taper is in the spindle nose. Smaller that a 4mt and bigger that a 3mt.
Was there such a thing as a 3-1/2 morse taper ?
10-26-2019, 07:43 PM #15
rustytool liked this post
10-26-2019, 07:48 PM #16
Yes, "half" - or perhaps more accurately "partial" - MT, from moving the gage line so as to select a shorter length than a full run so as to fit the space available, are not uncommon.
That would support use of common calculations, setups, even stock reamers, where a fully-proprietary taper would not.
Browne & Sharpes "jarno" - again as a selective "partial" - is less likely on a non-US machine tool.
UNfortunately... jarno at least has the same rate of taper, all sizes, something B&S and Morse did NOT hold to.
"I could be wrong.." etc. Any way you go, you'll want to measure what you have as accurately as you can do, then browse the published data for a match. Or for NO match.
No law against a proprietary taper. Holbrook wore long pants, could do as they saw fit.
10-29-2019, 08:48 PM #17
sandiapaul liked this post
10-30-2019, 06:13 PM #18
Just a FWIW
The orange rubber gasket goop isn't original, Holbrooks would never entertain such a thing………..and if your lathe left the UK after the mid to late 70's, it's every chance it's ''Hermatite Instant Gasket''****
Twitter to ban all political adverts | The Independent
**** AKA to us lads as ''gorilla snot''
10-30-2019, 08:54 PM #19
Took the front cover off the apron. The deeper I go I see that this machine has suffered from years of neglect rendering oil turning to varnish and rust.
All three shafts running through the apron just don't seem to be running very smooth and there is definitely something up with the feed shaft in the gear box end.
So I'm going into the gear box and will remove the leadscrew, feed rod and start/stop rod.
10-31-2019, 12:36 AM #20
I removed the gear box cover and didn't find any orange gasket like other places but did find evidence that someone was in there trying to remove the feed rod.
It's secured in the box by a taper pin through a collar on the end of the shaft. Without the cover off and the pump moved out of the way they would have needed a long pin punch but to reach the taper pin but I don't think they had one so they used a screwdriver and beat the hell out of everything. The pin, collar and shaft are pretty beat up. I'll apply some heat and let penetrating oil soak over night before I give it a few wacks.
