Holbrook C10 #10411 - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 73
  1. #21
    Apr 2011
    noth yorkshire-uk
    54
    45
    22
    I am sure the shaft will repair, the collar and pin I doubt are savable though lol
    Keep up the good work rustytool, to say the least it will be worth it!
  2. #22
    Oct 2010
    Moscow,Idaho,USA
    1,189
    1345
    571
    I tried all the usual tricks of heat, penetrating oil, tapping from both sides and in the end it had to be drilled out.
    Might be able to slightly over size the hole for the same taper pin size or just go up a size.
  3. Likes Limy Sami, Demon73, phm87, William Ward liked this post
  4. #23
    Oct 2010
    Moscow,Idaho,USA
    1,189
    1345
    571
    Disassembled the apron. The worms and wheels and half nuts look great. One shaft was badly rusted. You can see the hole in-between two of the gear teeth that was the passage way for oil to get to the shaft and the bronze bearing it runs in. The hole was clogged and without oil and condensation from the years of unheated storage is my guess as to what happened. The bronze bearing is undamaged. dscn0217.jpgdscn0214.jpg
  5. #24
    Apr 2011
    noth yorkshire-uk
    54
    45
    22
    Keep it coming rustytool, the more pics the better. The apron looks in great condition.
    Have you found any grease in the oil nipples?
  6. #25
    Oct 2010
    Moscow,Idaho,USA
    1,189
    1345
    571
    I've found grease in all the oil nipples. The plunger oil gun that came with the lathe was filled with grease. I've replaced that with oil and have cleaned out all the oil nipples.
    I've seen this lots of times before. "oil? That's crazy talk. Lets just grease everything and call it good."
    [ATTACH=CONFIG]269199[ATTACH=CONFIG]269201
    Attached Thumbnails Attached Thumbnails dscn0218.jpg   dscn0208.jpg   dscn0203.jpg
  7. Likes phm87 liked this post
  8. #26
    Apr 2011
    noth yorkshire-uk
    54
    45
    22
    Holbrook H-15 apron | MIG Welding Forum
    I know the feeling!
  9. Likes rustytool liked this post
  10. #27
    Oct 2010
    Moscow,Idaho,USA
    1,189
    1345
    571
    The pivoting power feed assemblies were tricky to remove and install. They are supported in the middle by a bushing that is held in place with a taper pin.
    One assembly needs to be placed in position and the bushing slide in farther than it's final position so the second assembly can be put in.
    Then the bushing is slide back and secured with the taper pin.dscn0219.jpgdscn0220.jpgdscn0221.jpg
  11. #28
    Oct 2010
    Moscow,Idaho,USA
    1,189
    1345
    571
    The feed rod overload clutch assembly.
    One on each side for the longitudinal and cross.
    When an overload occurs the rod with pointed end is wedged up and trips out the power feed.
  12. #29
    Jan 2007
    Norfolk, UK
    18,815
    14326
    14367
    Maybe some shall we say ''none believers'' will see what was meant by ''The thinking mans DS&G.
    FWIW The hand fit up and individual assembly time for each lathe must have been horrendous
  13. Likes phm87 liked this post
  14. #30
    Oct 2010
    Moscow,Idaho,USA
    1,189
    1345
    571
    There is a oil passage in the apron that lines up with a hole in the top half nut when the half nuts are closed (engaged on the leadscrew). Oil then flows and fills the little reservoir on top of the top half nut.
    The last photo shows the eccentric that opens and closes the half nuts and engages and disengages the lock out to prevent the cross feed from being engaged when threading.
  15. #31
    Jan 2006
    BC Canada
    438
    9
    I don't know if you are a member of the Holbrook group, but if not it's worth joining, there is a fair bit of Holbrook specific info on there. My brother did a write-up on timing the threading/feed gearbox for a C13, though the C10 box will be basically the same, I don't think it was a trivial matter.
    The group is in the process of finalising the move from Yahoo to Apple, so it may be a little while before all the files are accessible.
  16. #32
    Sep 2008
    Canada
    950
    373
    356
    Have used a few DS&G's and like them very much (altho would it be too much trouble for an Englishman to make a lathe for someone over 5'2" tall?) and have seen a few Holbrooks, including this one when it lived on the lower mainland. Have never used a Holbrook though. Not sure I understand why the C10 or C13 get so much adoration. Kindly explain?
    L7
  17. #33
    Oct 2010
    Moscow,Idaho,USA
    1,189
    1345
    571
    Is that the gear box on the front or on the left end ?
  18. #34
    Oct 2010
    Moscow,Idaho,USA
    1,189
    1345
    571
    L7, I haven't even run it yet so I can't say in that respect but just by observing the build quality it is very heavily built and without compromise.
    Like everything some people just like them and some don't.
    At 5'7" I like the height.
  19. #35
    Nov 2007
    Port Coquitlam BC Canada
    682
    11
    256
    36392ed1-2396-4850-8080-2b72411d011a.jpg5282f316-53eb-4d2d-9704-1057dc987c50.jpgHi Greg
    I like what you are doing with the lathe it’s just what I would have done only had no time to do that. What I liked was the stop rod for the carrage with four tools in the tool post I would use a 1 2 3 bock or shims to set the lengths for turning and parting of parts. I would say it’s better then a EE lathe. It will be a Gem when you have it back together.
    With down sizing the shop it is hard pick which machines to take so far it’s the oldest with the biggest swing looks like a pos and a picture of my first brand new lathe when I was 14 years old.
    Collector
  20. #36
    Feb 2009
    Colchester UK (where the lathes used to be made)
    1,933
    1337
    561
    Can I ask what number is on those collets?
    I have a set just like it that I have been unable to identify
    Bill
    Stop-press:
    Found them :-)
    They are the 1/4" to 1-1/4" set seen here on the right (the box has a hole in the bottom to let the collet closer tube run down through the mounting post)
    http://www.lathes.co.uk/holbrook-B-13-71-21/img19.jpg
    Quote Originally Posted by rustytool View Post
    The plain spindle bearing ones have a top speed of 2000 but the ones with roller bearings, like this one, top out at 3000.
    It has a set of tiny collets that are a proprietary Holbrook size that fit into the spindle with an adapter.
    Anyone know what the taper is in the spindle nose. Smaller that a 4mt and bigger that a 3mt.
    Was there such a thing as a 3-1/2 morse taper ?
    Attachment 268184
  21. #37
    Oct 2010
    Moscow,Idaho,USA
    1,189
    1345
    571
    Cleaned up the rack and start stop switch gears. They have timing marks punched in them which makes timing them a non issue. New felts for the way guards.
  22. Likes Limy Sami, Peter S liked this post
  23. #38
    Oct 2010
    Moscow,Idaho,USA
    1,189
    1345
    571
    Got the saddle and apron on and the leadscrew, power feed rod and start/stop/forward/reverse rods in.
  24. Likes phm87, Peter S liked this post
  25. #39
    Jan 2019
    Virginia
    151
    73
    33
    I agree with LimiSami in that this lathe must have been horrendous to set together. It is with equal respect that you accomplished an overhaul, if not rebuild of this complicated carriage.
  26. Likes rustytool, hermetic liked this post
  27. #40
    Oct 2010
    Moscow,Idaho,USA
    1,189
    1345
    571
    Got the gear box cover on. The only tricky part was having the worm gear in the proper rotational orientation so that when the sliding tumbler gear is raised it is in the proper position.
  28. Likes Peter S liked this post
