Turns out I got somewhat lucky here as this was the first gauge I have ever come across that actually had a cast or machined from solid bezel as opposed to most of the others I own which are made from thin sheet brass which was either spun or maybe stamped. I have a collection of these that my wife allows me to mount on our livingroom wall along with a few old machine nameplates.
On a side note I have always wanted to see the tooling that made the sheet metal style bezels as I have no clue how they supported the back side of the forming operation.
None the less having this made from solid rather than sheet metal made holding it on a lathe far easier as I don't know if the sheet metal ones would tolerate being chucked up in a conventional 3 jaw chuck.
Also chucking this gauge up with the bezel attached was going to be way too hard as it was a back mount gauge and the stub end protrudes about 2 inches which is deeper than my jaws. Plus as you will soon read the speeds I had to run at to get a good polish were a lot higher than I would want to go with a full gauge mounted on the machine. I wonder if the bourdon tubes could survive spinning that fast. Sure most likely this gauge will likely never again see pressure I don't want to be the guy to damage it further.
Once on the lathe I started slow but that didn't work well. The faster the better the results were until finally I was running at 2000rpm which is the fastest the lathe goes. I tried both simichrome and hard red buffing sticks. I found in the end what worked best was to rub the hard red stick against the bezel and then hold a towel against the part ready to let go if it snagged at a moments notice in what amounted to essentially an inverted buffing wheel arrangement. It wasn't much different in many ways than using emery cloth just a cloth towel. I found the red stick seemed to work even better than then tube of simichrome.
The challenge was doing the center as well as the back side where the fingers are too close to the spinning jaws for comfort. For those parts I found that wrapping the towel hard around a drill bit worked pretty well but not as good as my thumb.
In the end I am close to mirror finish but still not as good as i would like. It almost seems like no matter what I do there is still some tarnish or unpleasant looking finish on there.
I also polished away all the old plating so at this point I may try to get it nickel plated. I have seen the shop we use provide two finishes one super shiny that would look great and the other matte which I don't like so I may try speaking to them first. Any one more familiar with plating then I am know what causes that?
I am also tempted to try getting some citric acid and seeing how that works. Metalmagpie do you think that the citric acid would take this thing up to perfect shine from here?
Joe how big is the buffing wheel you use, I wonder if that may be part of the reason why I have had little luck on my buffing wheel with gauge bezels. The one I have is a hard wheel on an old bench grinder with the guards removed. I have noticed most better buffing arrangements also have a longer shaft which I think may be better for getting in there than my machine.
See below for a photo of it on the lathe. I am not sure how well the final appearance will come thru in the photos. The face is a different story. It cleaned up pretty well but has a white paint on top of brass finish on it. I am not sure how that one was done originally but I tried cleaning some of the rust streaks off it with some cleaner I had some luck and got the worst of the issues off but I couldn't push it too hard as some of the finish was coming off also. I am almost tempted to strip it all the way down to the etched brass but thinking it's better to leave it be.
While I have everyone's attention focused on gauges does anyone have any spare bezels or parts gauges lieing around for a 6" or 7" Ashcroft? If so I have a beautiful old Dillon Boiler Works gauge that a former asshole coworker either stole or lost when he promised to bring the bezel to the family's plating shop. After a whole year of him promising to bring it in "tomorrow" he got fired for unrelated lies never to be seen again. I always hope one day I will find a parts donor or less flattering gauge with a good bezel to restore that one. So I figure this is worth a shot if anyone thinks they have anything let me know and I will get the case diameter measurement so we can confirm.
Anyone know who the Carbondale Machine Works was and what they made I haven't had the time to Google them yet.
Lastly Joe Michaels, since I have you here did my email I sent last week ever make it thru? I want to make sure it didn't get lost in a spam filter. We're all cheering for you to beat your cancer.
Sent from my SM-J737V using Tapatalk
