Repairshop
- Apr 26, 2020
I've done ignition switches like this. One cheat is to simply machne away the crimped-over area to
diassemble. Often if you manage to uncrimp it, things do not go well when you try to re-crimp, the
crimped area then cracks off.
If you machine it away you don't damage the underlaid insulator, and then the choice is on now to
re-assemble, an adhesive will work sometimes.
I often replace rivets with nuts and bolts. You may have room in there to use nuts and bolts for reassembly if the crimp can not be redone.
Bil lD.
I've dealt with crimped electrical parts on old motorcycles. Typically, I get lucky and with a sharpened small screw driver and needlenose pliers, have been able to pry the crimping away to open up parts to access contacts, etc. Putting them back together, I've also been lucky as a rule.
As long as the plastic insulator (that the metal part is crimped around) is strong enough to handle the
stress, that will work. If it isn't then the insulator crushes and that's often the hard part to replicate/replace.
Dismantling stuff like this is seldom a one-size-fits-all situation.
....place in a plastic bag first so all parts are captured
Notice
