George:
I got your e-mail, but I have been out of town for a few days.
The spindle nut used in your lathe is a 29 degree, 3/4 inch diameter and 6 threads to the inch, left hand Acme. This was the standard tailstock spindle nut from August 21,
1905 until January 25, 1924. After that date, the size of the nut was increased and the
thread was changed to a 7/8 inch x 5 thread per inch, left hand Acme.
The nut is a press fit into the spindle and is installed and removed using an hydraulic
press. It is important to properly support the nut end of the spindle during the pressing
operation and use a 16 inch long, piece 7/8 inch drill rod with a pilot to fit the minor
diameter. The retaining screw is a 5/16" x 24 about 11/16" deep. If you are not able to
remove this screw, then don't attempt to press out the nut. Instead, bore out the nut,
the retaining screw (hendey screw # 276) shouldn't be hardened.
Because your chances of finding a commercial nut that will fit the spindle ( I don't have
any in stock), may I suggest that you make your own bronze nut. Once you have the
the nut pressed into the spindle, you can either drill and tap the retain screw hole in a
different location or use the original hole. If you use the original hole, it will be necessary to make a sacrificial half screw to allow the tap drill to remain centered. Also,
a simple drill jig with a boss that fits the minor bore of the nut and with a pilot hole at
the correct radius, will make redrilling the tap hole a simple job.
As I have posted before, Hendey used priority threads on many of their products and
their Acme threads are no different. A tap drill is not used for the minor diameter, but
is bored to a non-standard size. The tap produces a non-standard clearance for the
major and minor diameters. To make certain that the nut will give a good fit on the
screw, may I suggest that you send the nut to me for tapping.
Whether a tailstock spindle is reamed for a #3 M-H taper or a #4 M-H taper, all dimen-
sions are the same. It is always a much easier proposition to make and install a new nut
than make and install a new spindle screw.
Hendeyman
