Elam Works
- Oct 8, 2007
- Pennsylvania, USA
Hello All,
Need some help identifying an arbor support for a small/medium horizontal miller. Came with some odds and ends and is surplus to requirements. I figured I would put it up on eBay, but obviously connecting with anyone searching for such would be more successful if it was known what miller it came off of. The overarm is 2-3/4" diameter, the arbor bearing is 1-5/8" diameter and the center distance is 5-3/4". It does seem to be imperial dimensions, so I think the European mills can be ruled out. The Allen clamp bolt and general style indicated something that is not terribly old, but I do not recognize it as any of the common small to medium horizontal mills that I am familiar with. I even had a trawl through the lathes.co.uk site, but no luck.
-Doug
-Doug
