JHOLLAND1
Titanium
- Oct 8, 2005
- western washington state
So how's he know just how much to take off?
Last time I checked, static balancing was a valid, but not particularly accurate method of balancing. A short stubby bronze impeller would probably balance reasonably well with such a technique compared with a longer object like an induction motor rotor which would be more prone to balancing well statically but still retain dynamic imbalance. For a black sand bronze casting like that impeller, the pattern inaccuracies would impart a consistent imbalance to the one area of all the impeller castings that could be fixed by removing the same amount from one spot. Judging by the massive shaft it runs on, any remaining imbalance could be handled by plain bearings.
It's not a rocket engine turbopump running at 200K RPM, most likely an agricultural irrigation water pump running off a diesel for short periods of time at a few thousand RPM.
That was a tapered mandrel, not the finished shaft.
How do you figure it's run with a diesel engine for short periods of time ? What is your evidence from the video to support this claim ?
That impeller looks very much like the local sewage treatment
plants, they run 3600 rpm on a 20 hp electric motor 24/7
Notice
