Although I have yet to restore this drill press, I expect it will perform as well as the black one that I restored and now have in service. It took a little doing to deliver all of the torque from the motor to the spindle, but after lightening the lube in the hemisphere bearing and applying belt dressing to the drive belt, I can now stall the motor under heavy load and in the highest ratio on the variable drive. I'm looking forward to putting this one into service as well, but it will most likely take another 150+ hours of hard work to restore. The Albany Hardware Specialty Mfg. Co. did a fantastic job designing and producing a very robust, functional and "user friendly" drill press. After looking for years to find a floor model, metal working drill press with sufficient capacity and, most of all, an excellent variable speed drive, I'm glad to have "stumbled" upon these AHS drill presses. Attached is DP #2 as purchased, DP #1 restored and DP #1 as purchased.
