Checking out this older mill, everything but the rapid traverse seemed to work. We tried adjusting it per the manual and wound up with rapid traverse only, which didn’t require raising the r.t. Lever, all table movement power feed levers caused only rapid traverse. There is no feed at normal speed any longer. We tried backing out the adjustments we’d made but That lost all normal feed motion. We made the adjustments per the manual, on the rapid traverse clutch assembly, pictured. We pulled the locking pin out, then turned the big brass nut one hole at a time, allowing the pin to snap back into each hole around the clutch wheel, then tested the results. Suggestions?
