Results 1 to 7 of 7
Thread: Kearney and Trecker Model D
01-15-2018, 05:46 PM #1
I am looking for information on Kearney and Trecker Model D Rotary Head Milling Machine. Any and all information is welcomed. I found a thread early that seems to date it to 1925.
The Serial number is 58-1006-05-0
I know that it has:
460 V
3 phase
60 cycle
I am new to all of this and would love explanations on what everything means.
TIA
01-15-2018, 05:59 PM #2
Check your serial number... Should be on the column facing you... I think this machine came out in about 1939.. You may find information here:Kearney & Trecker Co. - Publication Reprints | VintageMachinery.org
Cheers! Ramsay 1
01-15-2018, 08:31 PM #3
That is the late format for serial, so a recent effort
Lot of 12 AFTER May 1969 - which is the latest date on that page, but for a previous lot - 1003
Last lot of 2D machines was 1007, also undated
This info on page 58-1 in the lot book
Thumbnails are scans from a brochure
01-15-2018, 08:47 PM #4
The 2D is a die makers mill. They had several attachments. It's a rotary head mill. I have one that I haven't had the opportunity to use yet. There I'd good information in publication reprints and a 1950s company video that has been put on utube. Watch the video. You will be impressed.
Collets are near impossible to find They only fit that machine
01-16-2018, 10:05 AM #5
Some 2d mills came with B3 spindle which is similar to R8 using a drawbar... The B3 collet is smaller than R8... I suspect my machine came with B3 spindle and somewhere along the line was opened up to R8... I use R8 collets and endmill holders in mine and they work quite well...
HERE is the 1955 movie "From Print To Product" from Kearney and Trecker which I acquired from an old K&T employee many years ago.. Thanks to Ed for posting: Kearney Trecker 2D Tool and Die Mill Jan 14, 1955 16mm Film - YouTube
Cheers: Ramsay 1
01-16-2018, 10:44 AM #6
11-13-2019, 08:29 PM #7
Questions about your d mill
I have a couple of photos of the serial number book I will put here thanks to ramsay1. I have a couple of questions for you about your machine does it have a coolant pump or just factory cover over the hole ? And does yours have a corrugated rubber hose for the coolant return to the base ? Do you have any pictures of the pump if it is installed? My K&T d model has a number of 58-1004 06 feb of 1972 number 6 of 8 yours appears to be nov 1970 5 of 12 Thanks ed
