I'm guessing this is going to turn into a weekend by weekend restoration blog
Went to some industrial surplus place up north today to get some casters.
Its basically a steelyard but he has a bunch of useful garbage laying around for sale. My kind of place
$14 later I had four casters (three with brakes) that would seem to fit my needs.
Open up my garage door to this:
Its a work in progress.....
The saw at that point was laying around in a storage unit (shop is two doors down). I needed some way of getting it to move and then uprighting it as well.
Using a random (and free! very important) board I had I made a base to mount the casters. I chose to use only three since the outside is uneven asphalt and I was afraid it would have difficulty sitting level.
Got the landlord to get his skidsteer and hoist the thing up, hence the blue strap.
After some gymnastics, it was sitting nice and level but I couldn't easily move it. A quick push with the skidsteer helped.
Unfortunately, it hit right on the crank handle for the vice adjustment and knocked off the outer ring
My fault. I was in charge.
I took off the bottom sheetmetal, where the coolant flows for the move.
Damn this thing is a monster.
I can't figure out where that triangular shaped piece on the bottom of the picture goes to. The cable to the coolant pump has an electric cable going through it. It was held by the cable when I got it.
There is a small coolant pump with a "Little Giant" brand name tag on it. Its dirty but no worse then I've seen in use before. Its a little electric thing which I am guessing was aftermarket.
There is an AB switch on the front leg. One wire to the motor and the other to the coolant pump.
Current tally of missing parts:
Vice Jaw (mentioned prior)
Hydraulic cylinder for downfeed
Above mentioned handle (possibly braze it back together?)
A piece of sheetmetal from the back (this could be easily fabricated I think)
Also, the gearbox is leaking a little. Which is good since it means that there is actually some oil in there preventing it from rusting shut.
Overall not bad, a little surface rust but no major corrosion. A little sand paper, a bath in the kerosene and some German machinery green paint will make it like new. The missing parts don't seem like they would be hard to fab together.
Plan for tomorrow:
Move into shop unit ( got some space cleared out there for it).
Figure out what to do with the casters. The front mount was not my best work to say the least. The brakes? Not sure if they work or not, seems to be stuck about half way on. Turns out they only lock the wheel not the rotation and I didn't think of that when I got them but I'm not sure if that's an issue.
The other,
main thing, I have to do is organize all the stuff in the back of the storage unit (i.e make it go up towards the sky! since I have plenty of space to go that way). If anyone wants to buy some science type stuff send me a pm I probably have an example of it somewhere back there
DaveKamp I'd love to add some wheels like that. Would a garden tractor trailer have a suitable axle? There is one on craiglist locally right now for $25. Or maybe I should try to find some other casters?
