borne2fly
Hot Rolled
- Feb 7, 2008
- California
The manual says to use grease for the tailstock Way lube points. There is a lube port like this above each Way. I have a hard enough time getting oil into these things without it squirting everywhere, so I can't imagine how to maintain a solid enough connection to pump in something like grease. Is there a trick to this? Maybe a special grease gun fitting? Or am I better off just using really heavy Way oil?
The other pictures show an attachment that came with this lathe. What is this thing? It looks like it should hold the ends of the leadscrew and carriage drive, but the geometry is way off and the bolt holes don't line up with anything that I can find.
Pictures are small but if you click on them I think they will pop up much bigger
