Landis Type C 16x72 Universal grinder 1942
Likes Likes:  0
Results 1 to 6 of 6
    Dec 2012
    AUSTRALIA
    3,610
    15
    1253
    Default Landis Type C 16x72 Universal grinder 1942
    I need to move a Landis grinder,Type C,16x72 Universal,WW2......I need a weight for the machine...I have the instruction book,no mention of weight ....I also have a Cinci book that does give weighs,and a similar size machine is under 10,000lbs......The Landis seems to me a lot heavier than this,as previously its been moved with mobile cranes ,where anything under 10 ton is OK......But I need to get it moved with a truck with mounted crane ,to contain cost .......there are plenty of trucks around can lift and load 5 ton,but over that ,Im into specialised movers and very high rates.
    Jul 2004
    Houston, TX USA
    31,519
    Universals are lighter than Plains, smaller everything like wheel and wheel head
    My ''47 14 X 60 B&S is less than 7000 - 14" wheel max
    Add 3000 for Landis extra length and good sense and call it good
    An example might be the similar vintage(Sept 1941) Norton 10 X 72 Type C PLAIN was 12,100. These would take up to a 30" wheel
    Oct 2009
    Oregon
    5,447
    5895
    2902
    Do you have Landoll type traveling axle trailers down there? That is an excellent candidate for to move with such a trailer. Then it doesn't matter what it weighs.
    Feb 2008
    southern il
    933
    164
    312
    I've got a similar age Landis that is smaller, like about 10x48................it is massively heavy. Very good load for a Case forklift. I would guess it at 8k.
    Apr 2018
    6,115
    2932
    Quote Originally Posted by rj1939 View Post
    I had a 50's 6" x 18" (with a 5* wheelhead, it was cool) and that sucker weighed about 5,000.
    Landis didn't cheapout on cast iron. You might try looking up an R for a guesstimate, but I think the older ones were heavier.
    Dec 2012
    AUSTRALIA
    3,610
    15
    1253
    There is a transport co moved in just around the corner from my yard,lots of big cranes ...catch is everything is new ,and a new Palfinger 24 ton /metre crane is $1/4M,add to a $200k truck ,and hourly rate isnt going to be cheap.......But then the scrap guy says he's got $1/2 M invested in each bin truck and bins.....and he dont charge me nothin to pick up .(Well ,$50 a ton actually ,what pickup pays less than yard price.)
