Lang lathe with Hydraulic Tailstock - Why?
Results 1 to 7 of 7
    May 2002
    Auckland, New Zealand
    4,657
    2506
    664
    Default Lang lathe with Hydraulic Tailstock - Why?
    This 20 inch swing Lang was advertised recently here in NZ. It has a hydraulic copy attachment, but also a tailstock which looks to be piped up to the hydraulic system.
    It sure isn't your plain old tailstock.
    Any ideas what this design was intended for?
    Was it just a quick way of retracting/advancing the ram, power-feed for drilling or something more than this.
    Hopefully the new owner reads PM and will chime in with some info!
    lang-20-inch-wanganui-01.jpg lang-20-inch-wanganui-06.jpg lang-20-inch-wanganui-02.jpg lang-20-inch-wanganui-03.jpg
  2. Likes Asquith, Jim Christie liked this post
  3. #2
    Dec 2012
    AUSTRALIA
    4,143
    20
    1483
    Copy lathes commonly have a hydraulic /or air tailstock ...speeds production....Does it have the later Lang trapezoidal ram in the tailstock?....Completely adjustable for wear,unlike the common round ones......Lang did make dedicated copy lathes on the standard lathe base......Havent seen one in a while....I scrapped a 22"Lang a couple of weeks ago.Was in surprisingly good condition for an old lathe......Lang also had a special chuck mount with a short taper ...works real good.....better than camlock by far.
  4. Likes Peter S, pressbrake1 liked this post
  5. #3
    Mar 2005
    Somerset, UK
    5,124
    938
    2066
    Interesting.
    Your are surely correct in saying that it provides a quick way of retracting/advancing the ram, power-feed for drilling.
    I can also see it being useful in maintaining a constant thrust load when machining a long workpiece that's getting hot and the blue chips are flying off. For this case there is presumably a pressure regulator to go with the pressure gauge.
    I note that there's a Vickers flow regulator, presumably used for the drilling power feed and fast retraction/advance features you suggested.
  6. Likes Greg White, Peter S liked this post
  7. #4
    Aug 2011
    Oregon
    2,664
    630
    804
    I've watched some youtube videos recently of David Wilks trepanning deep solids into tubes plus the center plug left over, and using a Lang lathe in some. I'm not sure if he used a special system attached to the carriage or not, but I think that's how he does it. (Boring steel tube to fine tolerance. - 0.005" for Honing. - YouTube)
    For tubes as long as he does I'd guess the tailstock isn't used at all, but for 2' long or less I can see how the one on the OP's photos would possibly work.
  8. Likes Peter S liked this post
  9. #5
    May 2003
    5,417
    22
    697
    The Lang tailstock looks remarkably like the hydraulic tailstock on the rare Monarch 1000ee lathe.
    Compensating for heat expansion was one of the points in advertising, and having the power feed quill to speed up other operations.
    Other then the pressure compensation, those tailstocks seem not easy to use other wise for general work.
  10. Likes Peter S liked this post
  11. #6
    Dec 2012
    AUSTRALIA
    4,143
    20
    1483
    The Lang tailstock also has an odd "diamond shaped-called trapezoidal" barrel,not round .....claimed fully adjustable for wear without removal from the machine.....The lathe in the OPs pics is mid 1960s.
  12. Likes Peter S liked this post
  13. #7
    Oct 2006
    Norfolk, UK
    937
    898
    389
    I worked on one like that in Cambridge. Drilling was fun,as there was no feel whatever,unlike turning the hand Wheel! Had to judge what was going on by the chip,I got away without crunching a single centre drill!
