Lathe i.d.?? Antique
Results 1 to 9 of 9
    Jul 2018
    Florida
    7
    Default Lathe i.d.?? Antique
    Just got this lathe for free.. Want to see if its worth doing anything with. I figured knowing exactly what it is would be a good start. No markings anywhere i can see from a quick visual look. It seems to have ahad a blueish gray color. Any help would be much appreciated.
    Attached Thumbnails Attached Thumbnails img_0142.jpg   img_0144.jpg   img_0145.jpg   img_0147.jpg   img_0148.jpg
    Jul 2004
    Houston, TX USA
    27,662
    Maybe Sheldon - knowing exactly what you have probably would be better enabled by some pertinent dimensions - and much larger photos
    Virginia
    19,533
    7561
    6220
    Quote Originally Posted by minimonsta22 View Post
    TS hints at some of Sebastian's earliest work.
    Move the carriage clear to each end and look at the front, vertical face of the bed casting for cast-in markings.
    Sep 2010
    moscow,ohio
    4,804
    464
    1461
    Suspect 8" Sheldon....scroll down to color pics here-
    Early Sheldon 9-inch & 10-inch lathes
    Jul 2018
    Florida
    7
    Some new developments and details. Although I was convinced that this was indeed an 8" sheldon lathe from the pictures on lathe.uk.co. I did find this tag on the threading chart on the gearbox cover that reads "monarch lathe company". The lathe ways are also 8" wide by 48" long. Is this a monarch lathe for sure?
    Attached Thumbnails Attached Thumbnails img_0156.jpg   img_0157.jpg   img_0159-1-.jpg
    Jul 2018
    Florida
    7
    Got a little more info after cleaning and some definite clarification. On the tailstock side of the ways, hidden under many years of dirt and grime is stamped "inspected by Carl Clark K279" Can anyone interpret this? What could a lathe like this be worth?
    Aug 2012
    California, Central Coast
    1,589
    1738
    505
    Jan 2011
    BFE Nevada/San Marcos Tx
    462
    362
    215
    Being that it was given to you, I think you should know what it is worth.
    Do you know how to use it, and want to keep it? Or just turn it for a fast buck?
    Aug 2011
    Oregon
    2,090
    374
    613
    It's a treasure, in some ways we are only curators of these old machines.
